Need Advice on A Chip - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-07-2011, 06:06 PM Thread Starter
gavol64's Avatar
I HAVE A 2003 6.0 CREW CAB SUPER DUTY 4X4 4" LIFT WITH $150K MILES . THE TRUCK IS IN EXCELLENT CONDITION. I HAVE OWNED THE TRUCK FOR TWO MONTHS. I HAVE PUT 5K MILES ON IT WITH TWO 400 MILES TRIPS. I HAVE HAD THE FOLLOWING MODS INSTALLED installed, zoodad, all fluids changed to Royal Purple Synthetic, EDGE CS, TRANSMISSION, COVER AND REAR END COVER UPGRADED TO LARGER CAPICITY COVERS, RANCHO 9 WAY ADJUSTABLE SHOCKS .
I DO NOT KNOW IF THE STUDS HAVE BEEN DONE. tHE TEMPS ARE ALL GOOD AND THE TRUCK PERFORMS FLAWLESSLY. I GOT 19 MILES THE GALLON GOING TO MEMPHIS THIS WEEKEND
My question is- If this was your truck would you install a chip?
Thanks in advance for your advice .
gavol64 is offline
post #2 of 8 Old 04-07-2011, 09:57 PM
You say you have a sweet running truck so the answer is NO heck NO shop time sucks plus you will need deep pockets for what use more fuel and blow smoke
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 8 Old 04-08-2011, 03:08 AM
duc796's Avatar
Theres a sticky on this in the performance parts discussion section of the 6.0 forum. I dont know of anyone that runs a chip on a 6.0 but most people including myself run an SCT tuner with custom tunes from a few different places, idp, gearhead... ect.
2005 Ford F250 CCSB 6.0 XLT 4x4
-SCT X3 W/ Innovative and Spartan Tunes
-4" MBRP Turbo Back Exhaust
-MBRP Cat Delete Pipe
-S&B Cold Air Intake
-Amsoil Everywhere
-CAT ELC
-Zoodad Mod
-Edge Insight CS with Pyro
-Sinister Diesel Coolant Filter
-Studded and Deleted
-6.4L Banjo Bolts
-2.5" Top Gun Customz Leveling Kit
-Bilstein 5100 Shocks
-35" General Grabber AT2s
Best track time: 14.1 @ 96MPH
duc796 is offline
post #4 of 8 Old 04-08-2011, 04:35 AM Thread Starter
gavol64's Avatar
I guess i need advice on a tune would you advice running a tune for fuel milleage.
thanks
gavol64 is offline
post #5 of 8 Old 04-08-2011, 05:24 AM
caissiel's Avatar
I have been using Max Energy and towing 15K with it for almost 4 years now.
My truck is stock and just deleted the EGR Cooler.
Flush out the Gold C..P and install ELC Cat-1 Approved Coolant before its to late.
2005, 6.0L, 6 Spd Std, 3.73 Rear End, F250SD, Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed, Max Energy programer by Hypertech, and Fuel Pressure Gauge. ScanGaugeII for 60 plus XGauges, and MPG. ELC Cat EC-1 Coolant, Pull a 39ft 15500Lbs 5th Wheel Camper Trailer. Mileage Avg is 20MPG, and pulling 12.6MPG.
caissiel is offline
post #6 of 8 Old 04-08-2011, 11:52 AM Thread Starter
gavol64's Avatar
thanks for the information. I will change the coolant .
Thanks
gavol64 is offline
post #7 of 8 Old 04-08-2011, 11:55 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You don't put chips on a 6.0.
I would get a SCT with tunes from Cale or BTS or TW..
I would never use any Redline product...IMO
CT Performance, Inc. is offline
post #8 of 8 Old 04-10-2011, 03:24 PM
caissiel's Avatar
I just towed my trailer from Crystal River to Daytona and averaged over 12MPG driving through cities and country roads. and on 95 I could keep the MPG at 15MPG at 70MPH. The level 3 is great for me and it kept the cooling fan from kicking in and robbing HP from my truck. Level 3 is a great mileage performer for me as I can pull my trailer on the interstate at normat speed and keep the load at 40 to 60 % and the water temperature stays at 95F.
caissiel is offline
