maybe trading 7.3 for 6.0? - Ford Powerstroke Diesel Forum
Old 04-07-2011, 05:29 AM
I'm thinking of trading my 2000 7.3 for a 03 6.0 with 220k on it? My 7.3 has been very reliable and I've heard some horrer stories with the 6.0 what do you guys think any advice? And also things to look for on the truck? Thanks sean
Old 04-07-2011, 05:41 AM
WHY ? Just kidding! If it were me I would keep the 7.3lpsd!! The newer 6.0 had more problems than the older ones , but just look at all the problems and how expensive they are to repair. 220k how many miles is that? How many miles does your 7.3 have on it?
Old 04-07-2011, 05:49 AM
Keep the ole 7.3 and put some money back and get you a 6.0 later on with a lot let miles
Yeah I would keep my 7.3 but its an excursion and it has 225k but i need a pickup and the 6.0 is a crewcab lariat I'm not sure about the 6.0 or not yet though
Old 04-07-2011, 06:08 AM
Id do it cant bet the sound of the 6.0 i would just save up the money to do the egr delete and flush all the coolant and put the cat stuff in it and you will be find. Also safe up for new hpop later down the road
Old 04-07-2011, 06:19 AM
It had an exhaust on it so does that mean the she is done already and what is hpop?
Old 04-07-2011, 06:23 AM
HPOP = High pressure oil pump. Just check the oil smell it good. The 03 6.0s were pretty decent motors. We have had more problems out of the 05 and 06's for some reason
Old 04-07-2011, 06:32 AM
Okay if it was bad what would the oil smell like? And what about the head gasket and head studs I heard they suck to is that true or no? Can I check if they are bad when im looking at it somehow?
Old 04-07-2011, 06:55 AM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
1.) get an oasis report to see if the truck was a problem child under warrenty
2.) get a car fax
3.) get a scanguage to check EOT and ECT temps on the test drive making sure they are within 15 degrees of each other
4.) flush out coolant and replace with an ELC
5.) EGR delete if you want (if you do do the oil cooler at the same time)
ive been very happy with my 6.0 but I only have 80k on mine. there are some with over 100k and no issues at all here as well, 7.3s arent exactly bullitproof, they still need injectors/glow plugs/hpops trans rebuilds etc, with proper maintence a 6.0 can be just as reliable as a 7.3, with a lot more power and a lot better fuel economy. the nice part about buying a high milage 6.0 is you can get them cheap from idiots that dont know the proper fixes then bullit proof them for what a low milage one would go for
Old 04-07-2011, 08:58 PM
if you need a truck trade your excursion for a 7.3 truck and keep on smiling down the road.
