help ! 6.0 headstud part list and install instructions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-06-2011, 04:19 PM Thread Starter
what would be a good parts list for a 04 f-250 90,000 miles with blown headgaskets.
imagine i will need.
arp studs
oem gaskets,intake gaskets,manifold gaskets.
4gallons of anti freeze
4gallons of oil
going to do the fpr spring upgrade and 6.4 bango bolts also
anything else?
i just did the oil cooler about 2000miles ago along with egr delete . i guess i waited to long to repair the oil cooler.
the oil cooler is within 3 degree unless i go 75-80 then its probable about 5-7 is this normal or could it be clogged already. when below 55 its 1 -2 degree difference
who has the best prices on the arp and the gaskets that i need?
does any one have a step by step on diy stud/gasket install?
what would be easier to pull the motor or lift the cab?
any one have any picture on what needs to come of to lift the cab?
thanks
mx730md is offline
post #2 of 3 Old 04-06-2011, 04:58 PM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
arp studs
4gallons of oil
anything else?
thanks
Have the heads check prior to going through all this.
Your temps look GREAT!
If you replaced the intake manifold gaskets last time, they are probably still good. They are re-useable.
Directions for your studs: read down the list of pdf files. Its there somewhere in the top 1/4 of the looooong page. <CLICK>
Turbo hardware kit should go on the list
If you don't have the updated turbo oil drain and the solid turbo oil feed line (no stainless steel joints), you might add those.
For the stock Ford gaskets (and all Ford factory parts such as the turbo oil lines and the hardware kit) try Tousley Ford. You can't beat them and they know their stuff. Call them @ 800-328-9552. To make it REAL easy to get the right parts, have the last 8 of your VIN ready.
Heres a place selling ARP's for $400. Is that good? I think so. <CLICK>
As far as the cab lift and whats involved, or if it is necessary....I will leave that to those that have done this.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 3 Old 04-06-2011, 05:30 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
thanks
if you really get serious about this pm me, I'll throw together a list of mostly the basics. I probably can't remember exactly everything but i can give you 99% of it off the top of my head
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
