Trans maintenance
I have 05 6.0 automatic. should I change fluid and filter or is flush necessary?
how many miles on the truck? its supposed to be done every 30-50k but if it hasnt been done in ~75k your better off just leaving it and waiting till it needs a rebuild
The recommended service interval of the 5R110 transmission is 30,000-miles. The only way to get a full fluid exchange is with a heated exchange machine or a lot of inginuity in maintaining an open thermostat inside the transmission.
I recommend a combination treatment initially and then you have a choice afterwards for long-term maintenance: First the initial treatment: 1. Drain the old transmission fluid. You will only get about 8-quarts although there are techniques that can get more fluid out. Take a sample for analysis at a laboratory. Here are a few that I have used: Blackstone Labs Predictive Maintenance Services, Inc. Oil Analyzers, Inc. - Oil Analysis, Oil Testing Services There are also over-the-road truck service centers that have a while-you-wait lab. 2. Drop the transmission pan for a thorough cleaning, making sure to give the gasket a good look as well as the magnetic drain plug. The gasket is multi-use so it doesn't necessarily require replacement. Don't worry too much if there is an accumulation of metal on the magnetic plug either. The used oil analysis will provide much more reliable data than the calibrated eyeball. Your first sample has no basis for comparison in any case with a physical observation - take a photograph if you wish to make any comparison later. 3. Replace the pan and refill with Mercon SP or Mercon LV only in the same quantity that you drained. Use the transmission dipstick tube as the fill tube but be careful not to use the oil fill tube - many people will perform multiple fluid exchanges and it is easy to mix this up - be forewarned. 4. Go to your dealer to get a full fluid exchange. Before you deliver your truck for the service make certain they will also replace the external filter. If not, replace the filter before you replace the fluid you drained. I use the NTZ filter from DieselFiltersOnline.com here: [NTZ09-C09B] - Ford Torqshift transmission external Transmission Filter(replaces FT145)-Includes O-ring - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks NTZ makes the filter for Motorcraft so you will save a little money without sacrificing quality...any other filter than NTZ or MC is asking for trouble. I have purchased BOTH the MC and NTZ filter and have physically seen the NTZ marking on the MC filter out-of-the-box. There are photos online, to include the DFO site. For long-term service you may either return to the dealer every 30,000 miles or perform a modified user-service such as draining the 8 or so quarts from the pan every year (10,000 to 15,000 miles would be typical) and exchanging the external filter at that time as well. It is a bit more frequent service and will never provide the cleanest fluid but will avoid the extreme accumulation of contaminants either - at least in theory. The only way to assure the quality is to regularly sample the fluid for analysis. Either at every annual "supplemental" exchange or bi-annual (or thereabouts) full heated exchange. The 5R110 is a great transmission. I have heard anecdotal reports of both techniques returning favorable results. Your choice is to rigorously maintain a consistent maintenance program with objective data such as from a used oil analysis program. Don't wait for a problem to make a fluid exchange. Get a sample and move forward. You'll be making a wise choice. Good luck! Jonathan |
Just changed mine yesterday, has 52,000 miles. I bought the external filter and 8 qts Merson SP from K-MansParts for $65 and took about an hour to change. The external filter housing will be very tight and tries to twist the lines when you try to loosen it, I found if you put a short piece of 2x4 between the filter head and fan shroud it won't allow it to twist and was able to break it loose with a breaker bar. The inside of the pan was very clean and very little metal fuzz on the magnet. Probably just my imagination but it seems to shift crisper and run cooler. The job was a lot easier that I thought it would be and saved several hundred dollars.
Look at my sig, that what I will be doing from now on.
I listen to BTS..never flush..drop the pan change the filters and add fluid every 30k. If you have a pre '08 replace the pan and stupid screen with a real filter and the '08 up pan.
Should cost less than $150 Filter #8C3Z7A098D Pan #8C3Z7A194B |
I had mine flushed by ford at 35k. I was going to just change it but got Ford to do it at their advertized price for the cars. I think I paid like $100 for the flush with the updated fluid!
Tranny Maintenance
Sorry for the delay in reply.80 k on a light used truck. Flushed, filter and fluid. will give specifics and oil anylsis info later. thanks for input.
