Coolant filter ball valve size? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-04-2011, 01:31 PM Thread Starter
Fox Hunt's Avatar
Quoted: 23 Post(s)
Just ordered the dieselsite coolant filter, but I didnt realize I needed to order the ball valves also. So does anyone know the fitting size so I can go to the hardware store and get them now and be able to do this all once my filter shows up.
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #2 of 6 Old 04-05-2011, 01:30 AM
Chapter Director
cubalz's Avatar
Just take the billet aluminum mount and hose as a reference and match them up. I have the same kit from Dieselsite but I bought the valves from them at the same time. I think that it is a standard size though and you can get them from NAPA.
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
post #3 of 6 Old 04-05-2011, 01:39 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
well i ordered them. i really dont see the need for them honstly. unless you change it running.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 6 Old 04-05-2011, 04:09 AM
mike 6.0's Avatar
less mess and no coolant on your belt.
mike 6.0 is offline
post #5 of 6 Old 04-05-2011, 04:10 AM
diablos30's Avatar
Quoted: 31 Post(s)
even when its not running it will leak out coolant when your changing the filter if you dont have the shut off valves.
diablos30 is offline
post #6 of 6 Old 04-05-2011, 04:44 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
well the issue i ran into was the pressure in the cooling system worked against me. i couldnt turn the filter till it was released from the cap. i had them both shut off before releavin the pressure. released it and opened the valve for a sec. yes it did stop the trickle i had from the hose comming down from the tank. no no coolant gets on the belt unless you spill the filter. in the end its like $10 i think so just find the ones that will work and use em. never know what will happen.
edit i just checked. man i think they went up cause i dont remember spending $18 on 2 valves
http://www.dieselsite.com/index.asp?...ROD&ProdID=570
Sold
LSP Group Threads
Jarrod B is offline
