Which coolant to use? - Ford Powerstroke Diesel Forum
Old 04-04-2011, 06:52 AM
I had read that non-silicate coolant was best for my 05 6.0. Now I had a powerstroke mechanic tell me that the green non-silicate I used is bad for the front cover. I don't have any mods to the engine and was trying to help the stock egr and all survive. What should I be using?
Thanks.
Old 04-04-2011, 06:54 AM
Illiana Chapter Director
Any ELC (Extended Life Coolant) with an EC-1 rating. The coolant will be red in color. DO NOT use Dexcool.
Old 04-04-2011, 08:00 AM
You can hardly look at a page on this sight without seeing a post about getting ELC.
Did you put SCA's/DCA's in your green coolant to protect against cavitation? If not get that crap out of there ASAP and flush well. Then put the proper ELC in it.
Old 04-04-2011, 08:23 AM
Any recommendations on brand?
Old 04-04-2011, 08:42 AM
The easiest to find seems to be Zerex ELC concentrate from your local Napa store part # ZXED1. If they don't have it they can get it in a day or so.
Store Locator | NAPA Online
Old 04-04-2011, 09:10 AM
Thanks for the info
Old 04-07-2011, 12:03 PM
Ordered coolant today. Anything special I should flush with?
Old 04-07-2011, 01:25 PM
I am going to do this flush as well but I am kinda a newbi. Would someone please explain to me exactly how to go about getting all the old coolant out, were to drain everything and were to fill the system up and what steps to take to do this. Also will the extended life coolant void my warranty if so what coolant can I run that won't void it. Pictures would be great. Also should I use the system iron cleaner first and how long do you drive around with this stuff in before you drain it out. Thank guys
Old 04-08-2011, 06:48 AM
Clean with Restore and Restore Plus. These are Cummins products and if you can't get them from a big rig diesel dealer (Not a Dodge Dealer) find your local Cummins Parts Distributor. I drain into a 14 gal container then transfer to a larger container. I take all of that to the recycle center. You fill from the degass bottle. No ELC won't void your warranty.
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one. You can skip the block drains if you want except for the final drain before adding fresh coolant. You will just have to flush a few more times to get the block clear.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with tap water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with water. Drive truck or run on high idle for 60-90 minutes. Drain and flush 3 or 4 times.
Add 2qts VC-9 or 1/2gal of Restore Plus, top with water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water if you are draining the block or 5 times if not. This is to replace any tap water in the cooling system with distilled water and very important.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
Hope this helps.
Mitch
Old 04-10-2011, 05:41 PM
Coolant
So, when I was at the Cummins place getting the Restore and Restore Plus, they talked me into getting their coolant. As I had not found any yet, I decided to go a head and get it.
So, now I have four gallons of their extended life coolant, but it is blue. Is this a problem? It is Fleetguard...
Thanks,
Andrew
