Door Chime - Ford Powerstroke Diesel Forum
Old 04-03-2011, 02:21 PM
IU Hoosier Fan
Door Chime
I was talking with Doug about the door chime... it gets really annoying to me but was asking him if he happens to know how to get rid of it... said he has been told a couple of ways... well we took mine apart and found a way to do it.. not for sure if it has been done like this or not (I'm sure it has)
but it's really quick and easy to do.... all I did was take off the little meatal clip and it works great now here are just a few pics of what I did
Old 04-03-2011, 03:12 PM
Yep that's a quick and easy way to do it. Unfortunately what you are going to find now is that when you use the interior power locks to lock your doors (with the keys out); your driver's side door lock will pop open again after 1 second or so. You'll have to either lock that door by hand or use your key fob all the time to lock up with. You're tricking the comp. into thinking the keys are in the ignition by pulling that clip. So the truck is unlocking that door so you don't lock yourself out!
Old 04-03-2011, 03:16 PM
IU Hoosier Fan
always use my key fob to lock it anyways.... unless I'm letting it warm up then I just use my keypad to lock it
Old 04-03-2011, 03:23 PM
IU Hoosier Fan
well.... just went outside put key in the ignition... doors lock with interior power locks... with the key in the run postion all doors will lock besides the drivers door... like you said it pops back open after a second or so.. which it done that before I took that tab off... and it will still lock all doors with the key out of the vechile if I use the interior power lock
soo... the only side affect I have seen so far is that the door chime doesn't go off with the key in the on/run postion... besides that all the same
Old 04-03-2011, 03:31 PM
i should do this in my dads truck because the door chime is on anytime the door is open even if the key is out
Old 04-03-2011, 03:32 PM
information regurgitator
Theres also a black wire, just under where the ignition lock cylinder is, just under that black cover on the underside. Give that a good tug to unplug it, no more <ding> <ding><ding>. Worked for me.
Black wire all by itself.
IU Hoosier Fan
I do not know if that would help it or not...
Old 04-03-2011, 04:42 PM
nope it wont, i just talked to him and he said he had someone try it for him and it didnt work, i would try the black wire but last time we did that to a car it disabled the ignition because of some alarm thing so we will probly just leave it....
Old 04-03-2011, 04:48 PM
The black wire is a ground that actually attaches to the very tab that he removed (more or less). The system works much like the horn, apply a ground to the circuit and it energizes. How that would effect an alarm system is beyond me. They must have installed that alarm incorrectly, if that wire had an effect.
Old 04-03-2011, 04:51 PM
yeah it probly was installed incorectly, it was in a 80's rv
