Help with Rize Lift
I need some help guys. I started installing my 8 inch rize kit on my 06 this weekend and ran into a few snags. I bought the 8 inch kit and im using fox shocks. The kit also came with the leaf springs.
The first question that I have is am I supposed to use the factory blocks with the springs or do i just use the springs? I was under the impression that you only use the springs, but they didnt send me any new U bolts and the stock ones were way to long without using the blocks. I used the blocks anyway now the front of the truck is 3 inches lower than the rear. The second problem i have is that the rear shocks dont fit over the top mounting stud that is attached to the chassis. It will go over the threaded portion but it stops when it gets to the part which is not threaded. Any help would be great. |
Almost forgot. here are a couple pics for those who might ask. Sorry for the poor quality.
![]() ![]() I dont have the dual stabilizer installed yet either. |
Well if the rear is 3in higher than the front then I would go find some new U-bolts and take out the block, you could also try driving the truck for a couple days or loading it to see if the spring will settle. Another ave. is if those fox shocks are coil overs, I know the kit doesn't come with shocks you have to supply your own, but if they are coil overs, how much do you have them cranked and/or are they dual rate. As far as the mounting stud it sounds like you just need to bore out the hole a little bigger to get the stud through unless I'm missing something, hope some of this helps...
Ok you loaded the pics while I was typing,you don't have coil overs so that idea is out, are the blocks indexed at all and/or are the springs for the right pinion angle? The easy way would be to get new u-bolts and take out the block, but is that going to throw off your rear shock travel, to where you are bottoming out? Nice truck by the way
Most shops don't re-use U-bolts since they are designed for one stretch. I'd replace the U-bolts and remove the block. I would also contact the manufacturer to verify the problems you are having and they may be able to point you in the right direction.
I have contacted the manufacturer and they are supposed to return my call soon with the answers. The rear shocks can not be bored out as they use spherical bearings on both top and bottom mounting points. I do think that I need new u bolts and to take out the blocks.
How about...
getting a few more inches out of the front. Can you adjust the radius arms and add a 2" leveling kit? I just did this with no problems with my Pro Comp 6" lift and now have 8" to clear my 22's. If this is something you want to consider check out ..:: Nor Cal Truck ::.. ..:: Home ::.. they have a bunch of F-250's in their gallery and most have rize 8" lifts and I'm almost certain a few of them also had the leveling kit too.
Scott |
here you go Josh
![]() This is the last truck in the gallery section for fords on that web site I mentioned above. Scott |
I agree on the adapter for the shock post a pic of the shock eye and the sshock mount in question. To the poster of the last pic, the brake line doesnt look long enough if the suspension is ever drooped out.
Russell |
