6.0 Remote Oil Cooler - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-15-2011, 08:51 AM Thread Starter
FordWake's Avatar
Anyone running the Remote Oil Cooler from Liberator Performance??
http://www.liberatorperformance.net/fordproducts.html
Scroll Down to see the kit from the link above
FordWake is offline
post #2 of 9 Old 03-15-2011, 08:52 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Forget about it. It is a piece of junk compared to the Bulletproof cooler. If you are going to do this do it right the first time.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 9 Old 03-15-2011, 09:04 AM Thread Starter
FordWake's Avatar
I really like the BPD kit, but it is overpriced. When you say piece of junk is there a real reason like it leaks, fails, etc etc?? I have considered putting together my own kit using BPD oil adapter and finding there source for the cooler and buying a cheaper oil bypass kit. There making a considerable amount off of these kits. I am all for capitalism, but I don't like to be the guy paying the inflated price because there isn't another option. I am in no way putting down BPD they have a well engineered system its just too expensive. If they cut some of the profit out they would sell more IMO.
FordWake is offline
post #4 of 9 Old 03-15-2011, 09:09 AM
Powerstroke Techie
Lilpooh's Avatar
Stick with Bulletproof, the Liberator kit still allows a chance for coolant to mix with oil if a seal should fail.
With a little bit of work and some cash, you could do what Liberator did if you made your own system with a external cooler and the remote oil filter from a E-series 6.0. But IMO, it's not worth it after you buy all the parts and do alot of research. The 6.0 can demand up to 18.5 gallons of oil flow a minute. So even if you buy a good hi flow cooler,E-series remote filter assembly, oil cooler thermostat with bypass valve, hose, and fitting you would have to find all this for dirt cheap. But still have a chance of the coolant mixing with oil if a seal would fail.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 9 Old 03-15-2011, 09:15 AM
Powerstroke Techie
Lilpooh's Avatar
FordWake, the cost is so high do to the research and development that went into BPD system, then add in the cost of machine time. It looks like BPD uses a similar cooler like the Setrab coolers which cost a couple of hundred dollars alone. Then if you live in a cold climate, it's recommended on using the there thermostat/bypass which cost $350. The part that BPD use arn't cheap, so the price to the buyer will be higher.
Lilpooh is offline
post #6 of 9 Old 03-15-2011, 10:27 AM Thread Starter
FordWake's Avatar
Don't I still have to worry about coolant mixing with the oil with the BPD kit? Seems to me the Oil manifold adapter could still allow this if the seal fails right?? I agree they are paying for the R&D of the kit with the cost being where its at. It is a really well engineered solution, but they are making a very very good profit per kit. I am again not putting them down. I just dont have alot of extra cash to spend on there R&D. I may end up getting there kit anyway. I am just trying to see if I can save some coin by piecing together my own kit even using some of there components. I was just looking for some good/bad opinions on the liberator kit because I have seen no one use it. I appreciate the responses
FordWake is offline
post #7 of 9 Old 03-15-2011, 12:38 PM
Powerstroke Techie
Lilpooh's Avatar
Yes there is that slight chance for coolant to mix with oil, but it is just that one seal where the coolant leaves the block to the adapter. Where as on a stock unit, you have that seal leaving the block to the housing, and the other seal that is sandwiched in between the two halves of the oil cooler assembly. I don't know if Liberator has eliminated that second seal so it would lessen the chance of failure. Seal failure for the oil cooler isn't a common problem with us.
You can check out this link, this guy looks like he has done something similar to the Liberator set up.
DIY Oil Cooler Delete with Bypass Filter
You can also read up on what this guy did.
http://www.thedieselstop.com/forums/...2003-a-245088/
Lilpooh is offline
post #8 of 9 Old 03-15-2011, 01:14 PM Thread Starter
FordWake's Avatar
Thanks alot lilpooh exactly what I was looking for. More info. Yeah I would like to eliminate the second seal. My goal would be to make a plate or buy the Oil manifold adapter from BPD. There needs to be a competing company on this to drive healthy competition and better consumer pricing IMO. Heck I may do it. Thanks alot.
FordWake is offline
post #9 of 9 Old 03-15-2011, 01:24 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
No the BPD kit does not allow the coolant and oil to mix. Well its extremely unlikely at any rate.
Do not waste your time with the liberator kit. Its pure garbage
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
