Plugging in, How much time needed? - Ford Powerstroke Diesel Forum
Old 02-26-2011, 05:26 PM
How long do you plug your truck in for before starting? Is there an optimum time? I am wanting to set my plugin on a timer so i need to know how long to set it to come on before i want to jump in it and leave for work. Thanks
Old 02-26-2011, 05:31 PM
Powerstroke Techie
Feedback Score: 3 reviews
i have mine set to go on at 3am and i leave around 7
i think 3-4 hours should be long enough
Old 02-26-2011, 05:35 PM
The Tamed Racing Driver
x2^^^^^. I've been told after 3 hours its as hot as it will get.
Old 02-26-2011, 05:44 PM
All night long.
Plug it in when I get home and forget it until I drive.
Old 02-26-2011, 05:55 PM
This is what I used to do. These heaters use alot of current but I'm not sure how long it would take to justify the $10-$20 a timer costs. I figured I would have my diesel a long time so I could justify it.
Old 02-26-2011, 06:01 PM
Powerstroke Techie
it's a 1000 watt heater so you're looking at 1KWH of electricity per hour of usage
Old 02-26-2011, 06:02 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
~2.5 hours or so mine is set for
Old 02-26-2011, 06:05 PM
How much is elcetricity per KWH. (I've only been renting this house a few weeks so I havn't got an electricity bill yet)
Old 02-27-2011, 10:00 AM
I plug it in for around 3 hours with a timer, but only when it is below 20deg. When it's above 20deg I don't plug it in.
The energy consumption is around the same as a little space heater so it probably cost around 50cents to $1/day depending on how long you plug it in.
Old 02-27-2011, 02:40 PM
I think the powerstroke supplement that came with my owner's manual recommended 3 hours, but it really depends on how warm you want it to be. If I do mine for 3 hours on a 20* day it will be about 85-90 on both ECT and EOT. If I do it over nignt, it's usually around 130* for both, but once I start it the warm fluid cycles through and levels out around 100*.
