Another head gasket question
I plan on doing this next month. I have a 2003 f350 srw with 155,000.Here is a parts list I have ready for the job.
Victor Reinz head gaskets Victor Reinz exhaust gaskets Victor Reinz intake gaskets Updated oil feed from ford Updated oil drain from ford Fuel pressure regulator kit from ford Turbo hardware kit from ford Ford oil cooler with updated screen Powermax ![]() 8 injector o rings kits 2 High pressure oil feed tubes Is there anything else I need to update? (parts wise) Am I missing anything? Is there instuctions on how to do this job here? Any help is appreciated. Last edited by BigBear713; 02-25-2011 at 01:57 PM. |
I did not purchase the master set. Was I suppose to purchase the master set?
Don't have to, but those parts come in that set.
How many miles on the ICP sensor? Check for oil leaking at ICP and the pigtail wire harness, replace the ICP and wire harness if bad.
http://www.forddoctorsdts.com/articl...icle-10-06.php While you have the engine wire harness disconnected, check over the whole harness for chafing/damage. http://www.forddoctorsdts.com/articl...icle-05-11.php |
Umm you need studs and an EGR delete!
What he said^^^^^^^
Also send your heads out to be checked for cracks and warpage. |
I replaced the icp at 100,000 but after reading the articles. I will check the icp and harness. Thanks! |
I was going to order the studs from brown diesel next week. Is that the best price for studs? The egr delete I was looking at is on ebay. Dicad solutions FORD 6.0L 03-07 EGR DELETE KIT F250-F450 POWERSTROKE - eBay (item 300528615049 end time Mar-02-11 10:18:23 PST) I saw a thread in here ,and the guy said it looked like a good kit. But I also saw this kit 6.0L FORD UNF DIESEL EGR VALVE DELETE KIT - eBay (item 280584225794 end time Mar-03-11 05:45:33 PST) what do you guys think? |
The International dealer here in Houston was nice enough to give me the number to the shop that does all their head work. The guy at the shop said it would be around 100 each head with machine work and to check for crack's. That seems like a pretty fair deal to me. But I have never had head work done so I don't know. What do you guys think? |
