ECT gauge install question
05' f250 - Where do i route to? I'm using the ev2 isspro gauges. I researched it a bit, one of the only places i saw listed was at the engine block plug on the drivers side. Are there any other options or is this best place to put it?
could i tee into one of the lines from my coolant filter? |
anyone......anyone.....bueller
Anyone with analog gauges running a ect, where did you tap into? |
There is a coolant temp sensor near the t-stat as well.. would be the most accurate place next to the block. You could tap the bypass lines, but it wouldn't be as accurate due to filter clogging, heater core, etc...
i have a coolant filter that has 2 extra ports, im going to tap into the filter head for my gauge
guess i should of been looking harder. Here is what i just found in case someone else runs into this
ISSPRO Metric Adapter M16x1.5 (male) x 1/8" NPT (female). Can be used for Ford 6.0L water temp. sender. (Installation Image) Part #: R7964 Price $8.36
