Hawk LTS or HD Brake Pads? - Ford Powerstroke Diesel Forum
Old 02-22-2011, 07:59 PM
Braking on my truck is under par IMO, so I'm going to try putting new pads on first, before I look into getting different rotors. The stock rotors I have appear to be in good condition, so I'm hoping new pads will make the difference.
Hawks website says the HD pads are for trucks over 1 ton and hauling excessive loads. LTS pads are for "Light Trucks". I think I fall in between. I hate to think of my rig as a "light truck".
Who has Hawk pads, which ones, and what are your impressions?
Old 02-23-2011, 08:27 AM
I ran Hawk LTS pads, but they were on my Jeep Liberty. I actually liked them quite a bit. They didn't dust as much as I thought they would. Not an apples to apples thing, but I'll probably get the LTS pads again when it comes time to do them on the 250.
Old 02-23-2011, 10:24 AM
I run the SuperDuty pads on my truck and have run them on several others. I like them a lot. The LTS is not a bad pad either and doesn't dust quite as much but also doesn't have the staying power of the SuperDuty pads.
Old 02-23-2011, 03:30 PM
Feedback Score: 5 reviews
LTS..unless you tow often and heavy IMO then get the HP's..they require more heat.
Old 02-23-2011, 04:21 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
i ran them on my mustang and they dusted and didnt perform any better then motorcraft pads, so that is what i run now, powerslot rotors up front, stockers in the rear. (rotors are cheap, do it all at once)
Old 02-23-2011, 04:33 PM
Did you re-use the old clips, or did the pads come with new ones?
What about what this:
Old 02-23-2011, 04:53 PM
They don't come with new hardware just the pads. A SuperDuty F250 CCLB for sure weighs a bunch more than a Dodge or a Chevy. Coming in at around 8k lbs our trucks are no lightweights. No question they work best with a little heat in them but they also won't fade as soon as the LTS and they have plenty of stopping power cold.
Cary and I have agreed to disagree before. This is really a matter of personal preference. Either one works fine.
Old 02-25-2011, 04:30 PM
X2....either way you will be happy..some of us just drive faster and have to stop more
I wouldn't bother with new hardware just check yours, clean and use a little brake lube if they are still usable.
