06 die after going to car wash - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-22-2011, 10:29 AM Thread Starter
Live about 5 miles from car was. Die on way home. Had water in fuel light on.
Change both fuel filters. Put some 911 in top filter housing. And some in the tank. Both batt die while doing this. Forgot to turn key off from getting towed home. Hooked jumper up to buddies truck (driver side batt to driver side) truck rolls over good but will not start: dunno: any buddy have any ideas
05 F350 SC FX4 sortbox
DYI coolant filter
4” turbo back
AFE stage 1 air fliter
SCT sf3
edge insight CTS
owenkicker is offline
post #2 of 9 Old 02-22-2011, 12:15 PM
did you prime your fuel system? i would also suggest recharging the batteries, and see if your getting a rpm response when cranking. water may have damaged your CPS and the water in fuel is another issue, you fixed one but maybe it masked another?
but mostly, i would suggest recharging the batteries and getting them up to their cranking power.
RollingCoal is offline
post #3 of 9 Old 02-22-2011, 03:16 PM
bfrank81's Avatar
When you changed the lower filter did you open the fuel/water drain plug?
Brian
bfrank81 is offline
post #4 of 9 Old 02-22-2011, 03:31 PM
scotty2280's Avatar
do u have a computer to scan the codes?
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #5 of 9 Old 02-23-2011, 02:28 AM Thread Starter
I don’t have a computer to scan with and no we did take the plug out. I figured changing the filter would have removed any water that would have been in there..
DYI coolant filter
4” turbo back
SCT sf3
edge insight CTS
post #6 of 9 Old 02-23-2011, 02:54 AM
scotty2280's Avatar
You need to drain the plug.......that's what its there for.
post #7 of 9 Old 02-23-2011, 03:04 AM
mike 6.0's Avatar
If you change lower fuel filter won't that remove the water or am I missing something?
mike 6.0 is offline
post #8 of 9 Old 02-23-2011, 03:42 PM Thread Starter
took the drain plug out tonight. and it looked like water came out ???
was going to take the top filter out to see if or how fast the top filter would fill up. and would you know it. i broke the &$^&^@!%#! top plastic filter cover.
but the top filter did fill up fast so i guess when i get the new cover will see if it will start
DYI coolant filter
4” turbo back
SCT sf3
edge insight CTS
post #9 of 9 Old 02-24-2011, 04:25 AM
<ST>6.0's Avatar
not to hijack but a similar thing happened to me a few months ago i went through mikes afterwards the transmission was jacked up wouldnt shift right stayed in first gear cleared the codes worked fine for a minute then acted up again cleared the codes again and has been fine since...... wierd guess ill be handwashing this summer lol
2004 Harley Davidson edition, Edge juice with attiude, work horse chip, 4" turbo back exhaust no cat or muffler, river city diesel egr cooler delete and up pipe, S&B Intake, Pro Comp level kit, Pro Comp twin tube steering stabilizer, Sinister coolant filter, smoked tails, smoked corners, Recon smoked cab lights, Pioneer dvd, 2 Kicker 10's
<ST>6.0 is offline
