Tightening up steering box...
like the title says....I remember seeing a thread about this and was wondering if anyone has tried this? I currently have 1-2 inches of lateral play in the steering wheel before the wheels actually turn. I am only running a frint leveling kit and also running a TGC dual stabilizers kit. My rims and tires are 22in rims with 35in BFG ATs.
So any input from ppl that have tried this method would be a great help |
I just put on 35s and got the steering wheel play as soon a I did that. I have a dual steering stabilzer as well. Im not sure theres gonna be a fix im getting alignment tomorrow. Ill ask the tech. but i didnt have a problem before lift and tire, im curiou did you leave on the factory steering stabilizer?
Subscribing
I did it. There are 2 jam nuts on the top (16 and 18mm I think) and once you break them loose just take a 5.5 or 6mm hex head and give it a twist. Its a pain to reach. I took some side snips and notched a small part of my fan shroud. It helped a lot. The nuts break loose best from wheel well and you have to remove your airfilter box to get the hex in there. An extra set of hands is very helpful to keep the nuts from retightening. I went in small increments and it took me 3 times but it did help.
Well this is making me really want to try this out but I have ppl telling me that it could possibly really screw up my steering box.
yes its on top. It didnt mess up mine but like I said small increments. I was afraid of getting it to tight and having it not steer at all.
![]() I got this same issue and the Dealer said i needed a stabalizer last year, they even paid for it and installed it which helps when you hit bumps but i still have the slop in the steering. I have been told everything from live with it, to your truck is lifted and its the tires. I can agree a little with my tires but there not that big and i dont have a lift. |
A stabilizer will help if yours is bad. I tightened my box because I had visible slop in the sector shaft.
I was told that play was from my bushing in the panhard bar/locating arm. Granted there is a very small amount of play if at all there. But I also thought it was in the steering box... Will have to have this checked out as well. thanks for the post, helps out my problem.
