EGR delete and Head Gaskets and studs!
I have the EGR delete kit ready to roll! I am getting ready to pull it ALL apart to do the head gaskets and studs also! I am getting a new oil cooler to go with all this! Is there anything else I should do while I am all open???
Where is the best place to get the ARP studs/gaskets? Trying to keep this project down as minimal as possible. THANKS IN ADVANCE FOR YOUR COMMENTS!!!
What year is your truck? Updated turbo drain? STC upgrade?
hpop screen, dummy plugs, turbo drain pipe, STC fitting (if 05+)
, fuel pressure regulator upgrade, 6.4 banjo bolts Im probably forgetting a few things |
id buy a whole kit from mkm/sinster. then you have every gasket,nut bolt ect...
MKM Customs - Engine Components |
Dont mean to get off topic but is the 6.4 banjo bolts really worth doing?
solid < $20 piece of mind
Is the hpop screen in the hpop, or is it the screen under the oil cooler?
screen under the cooler, the updated one has a metal mesh screen instead of the paper the ones from the factory uses
Thanks, thats what I thought. The new oil cooler kit has it in there.
