FICM Help - Ford Powerstroke Diesel Forum
Old 02-20-2011, 12:58 PM
FICM Help
Ok so my insight was showing the famous FICM code so I decided to check my voltage today. With the key in on my lowest reading was 47.6V...now here is my question. Do I need to check it with the engine running? I have seen people say yes and no.
If I dont need to then what reason is there that I am still showing this code but by FICM is fine?
Thanks in advance
Old 02-20-2011, 01:05 PM
Normally I would think 47.6 KOEO is good enough, but since you're having issues I would think measuring KOER would be prudent. As for your other question, the cold/defective soldier joints is not the only way a FICM can/does fail.
Old 02-20-2011, 01:14 PM
I will check and report back. I am showing no signs of a bad FICM other then the dtc...thats why I am checking this. If I am showing the proper voltage shouldnt it be doing its job?
Old 02-20-2011, 02:07 PM
You need to check it KOEO and while cranking (disable glow plug module). Anything below 45V is a bad FICM but as previously posted just because it shows correct voltage doesn't necessarily mean it isn't junk. What code/codes are you showing?
Old 02-20-2011, 02:14 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
+1 to checking while cranking, mine was 48 with the key on, and dropped to 28 while cranking so i replaced it and she starts good as new
Old 02-20-2011, 02:30 PM
Powerstroke Techie
Feedback Score: 3 reviews
there is no reason for you to flag that code with the ficm being okay. replace it before you get stranded somewhere
Old 02-20-2011, 02:39 PM
seen this yesterday. might help they have a good video on it
Circuit Board Medics
hears the video
http://circuitboardmedics.com/?page_id=312
Old 02-20-2011, 04:42 PM
Ok well I was by myself so I couldnt check cranking but running it dropped to 37. Im going to ford to see if I cant get it under warranty still.
Old 02-20-2011, 05:16 PM
Powerstroke Techie
they'll probably just give you a half shell. entire ficm replacement requires prior approval now.
Old 02-20-2011, 05:28 PM
I just sent my FICM off to circuit board medics yesterday. I was getting a reading like 25 amps with the key on and only like 10 while cranking. The problem issue I have is that when we took the FICM out we noticed that the center plug underneath was unplugged. I got really excited thinking maybe that was my issue. We plugged it back in and tried again. still no start so we finally decided that the plug must have just come loose while we were trying to get the FICM out. IM REALLLLLYYYY hoping the FICM is my problem otherwise Im out of ideas and Im going to have to tow it to the shop.
