"Wicked Wheel" for an 03 6.0 turbo? - Ford Powerstroke Diesel Forum
Old 02-18-2011, 05:21 AM
Is there a "Wicked Wheel" type compressor wheel for an 03 6.0 turbo or is a stock replacement the only option. I noticed a small chip out of the corner of one of the blades on my turbo when I did my CCV reroute and want to replace the wheel. Any suggestions on where to buy would also be helpful, thnks.
Old 02-18-2011, 07:21 AM
Unfortunately the 6.0 is not that easy unless you want to take the gamble. Upgrading the compressor wheel as your asking is considered a Stage 1 turbo. The compressor wheel gets replaced and the housing needs to be machined to make it fit properly.
You could try swapping it out with another stock compressor wheel. I can't say where you might find just the compressor wheel new in the box.
Old 02-18-2011, 01:25 PM
I researched it and found out you can not buy the "compressor wheel only" for the 6.0 turbos, you have to buy the whole cartridge. The dealer wanted $1200, but I was able to find a new cartridge through a Garrett distributor for $679.
Old 02-18-2011, 01:54 PM
Have you just looked at a new Garrett Powermax.
It is a GREAT upgrade for about $1200
