lots of smoke and no power...? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-16-2011, 06:53 PM Thread Starter
Hello everyone,
I have a problem with my truck and I need your expertise in solving the problem. Here is the story. I drove my truck about 30 miles from work to a hardware store. Most of the driving was highway the last 8 or so miles was city driving. Turn the truck off go inside and pick up what I need 5-10 minutes. Start the truck, no power, but idles, in gear step on gas pedal, will hardly move and struggles and smokes like a train(white smoke). Stop put it in nuetral, then in gear again, step on gas pedal and same thing, no power, smokes, and barely moves, but it moves maybe 4 parking spaces, starts getting better and then all of a sudden the smoke goes away the power goes up and the truck drove fine. That happened about a week ago and the truck has been fine since. The outside temperature was about 25 degrees that day. Please help me solve the problem. Thank you for the help.
Will
fishmanwill is offline
post #2 of 10 Old 02-16-2011, 07:03 PM
any DTC's?
russf is offline
post #3 of 10 Old 02-16-2011, 07:10 PM
jetjock15's Avatar
Quoted: 113 Post(s)
failing injector, pay ford to run the codes, it will show
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 10 Old 02-16-2011, 07:11 PM
njmudrat's Avatar
Quoted: 8 Post(s)
I have an 05 and has done this 3 times.Once 3yrs ago when I first got it than about a yr later and another year after that....Your description is exactly what mine did...It is very stange..
2005 f350 Lariat,,Stock for now--Television, the internet, ipods, all influenced by POS trashy celebrities. The people that try to help raise kids in a positive way Teachers and Cops are now the sworn enemy.
njmudrat is offline
post #5 of 10 Old 02-17-2011, 04:59 AM Thread Starter
It does not show any codes. I hooked it up to my buddys bullydog just to check codes and there were none. It still runs great, so I dont know.
Will
post #6 of 10 Old 02-17-2011, 05:02 AM
Snake's Avatar
Quoted: 47 Post(s)
Bullydog and SCT aren't good for truly diagnosing a problem. You need a Scan Gauge or something similar. I bet if you took it to the dealership and asked them to pull codes they'd find some.
Snake is offline
post #7 of 10 Old 02-17-2011, 05:07 AM
Davey~do's Avatar
Scan Gauge, Autoengininuity or Ford scanner, take your pick. They'll let you know if it's an injector and if so, which one it is.
Davey~do is offline
post #8 of 10 Old 02-17-2011, 06:34 AM
Arctic Fox's Avatar
Quoted: 9 Post(s)
Feedback Score: 8 reviews
Originally Posted by fishmanwill View Post
Turn the truck off go inside and pick up what I need 5-10 minutes. Start the truck, no power, but idles, in gear step on gas pedal, will hardly move and struggles and smokes like a train(white smoke). Stop put it in neutral, then in gear again, step on gas pedal and same thing, no power, smokes, and barely moves, but it moves maybe 4 parking spaces, starts getting better and then all of a sudden the smoke goes away the power goes up and the truck drove fine.
When my '06 F350 had the exact same symptoms, the dealer ended up replacing the FICM (still under warranty) and that fixed the problem.
Looking back on it now... I think the whole issue started when I returned from a 2 week business trip where my truck had been parted at the airport, I returned to find the batteries were dead and I had to get a jump start late at night in zero degree temps. I also replaced the batteries after getting the new FICM.
2006 F-450 XLT 4x4 Auto 4.30L Alcoa 19.5" 16,000 GVWR
Kelderman 4-Link/4-Bag Rear Suspension, Lariat Seats, '08 Console, '11 Mirrors, CTS, SCT X3
ARP's w/OEM HG, BPD 6ph FICM @ 58v, BPD Oil Cooler w/stat, Ported Intake, 185 amp Alt
P-Max w/WPE billet wheel, Spearco IC, 4" Banks Exhaust, Shell T6, Zerex EC-1, Oil bypass filter
50,000 miles
Arctic Fox is offline
post #9 of 10 Old 02-17-2011, 12:06 PM
njmudrat's Avatar
Quoted: 8 Post(s)
I had mine checked when it first happend and they found nothing..But had the ficm replaced recently so maybe thats been the problem all along..
njmudrat is offline
post #10 of 10 Old 02-17-2011, 04:08 PM
jjeffrey69's Avatar
I had the same problem. Check the voltage on your FICM! I will be willing to bet, its starting to go out on ya! You can find out how to check it yourself online pretty easy!!! Follow close! DO NOT SHORT OUT WHEN CHECKING! I would get ahold of SWAMPS diesel performance if ya need a new one! They did awesome for me!!
04 ~ F350 Crew Cab 6.0 4x4
Swamp's 58 volt FICM.
EGR Delete/ Bullet Proof kit
MBRP 4" Turbo back straight pipe
SCT tuner~ Custome tunned by Innovative
Warrens 205 cc Injectors
Garrett Powermax Turbo
Banks intercooler/ wide mouth intake
Driven Diesel Regulated fuel return kit
Fass fuel pump
S&B cold air intake~ "oiled"
Ford OEM head gaskets
ARP head studs and bolts
Edge Insight~CTS Monitor With Pyro kit.
SNOWS~ Stage One Methanol Injection Kit
Cepek~Torque Rims / Cepek Tires
jjeffrey69 is offline
