hard start - Ford Powerstroke Diesel Forum
Old 02-16-2011, 09:04 AM
hard start
there was a cold snap here and when tried to start the truck the batteries were dead, once charged I tried to start the truck and it was very sluggish with black exhaust, it would not start until I plugged it in, the glow plug light comes on and the controller is hot to the touch, could it be that the batteries dying could have done something to the controller.
Old 02-16-2011, 09:31 AM
Feedback Score: 3 reviews
How old are the batteries?
Old 02-16-2011, 09:58 AM
I don't know, I bought the truck last summer, I put a trickle charger on them and it turns with no problems right now it is just the starting that is sluggish.
Old 02-16-2011, 11:14 AM
If you don't know how old they are, do yourself a favor and get new ones. Weak batteries can damage the alternator, FICM, and injectors. This could lead to very costly repairs. Alway replace batteries in sets, never just one battery.
Old 02-16-2011, 11:54 AM
they are holding a charge, I charged them to 13 volts ant they crank the truck with no problem now, do you have any thoughts on my hard starting problems, do you think it might be the controller
Old 02-16-2011, 02:58 PM
When you tested the batteries, did you unhook at least one so you can test them independently? If the are hooked up together in the truck you will get a false reading because the good battery will show the higher reading when still hooked up in the truck. The batteries run in parallel with each other.
Old 02-16-2011, 03:52 PM
Send a message via AIM to mustangman02232 Send a message via Yahoo to mustangman02232
i really dont care what my batteries test as, i put 2 new interstates in every 3 years or so, for $230 its cheaper then a ficm, alternator or starter, and worth it not not ask the guy with the dodge across the street for a jump
Old 02-16-2011, 08:59 PM
The recommendation to do a proper battery test is the best advice you can get at the point you are at. Voltage tests mean nothing unless it is under a proper load.
You have a Dc-DC converter board in an onboard processor that steps up voltage from 12V to 48V. This 48V system opens spool valves in your injectors. The processor is called a FICM - Fuel Injection Control Module. It is very sensitive to proper voltage on start-up.
Low voltage can fry it and it is not cheap.
Old 02-17-2011, 08:13 AM
ok I will try changing the batteries first, either one of the batteries is bad and providing enough amperage to run the glow plugs or the controller is bad and not turning on the plugs, I checked to codes last night and there are no glow plug codes showing. with one battery bad can you have enough in your system to crank the engine but not run your glow plugs
Old 02-18-2011, 12:51 PM
I put new batteries in and still does not want to start, I think it might be the glow plug control module, I tested to see if it has got 12 volts going in and it does, an anyoune tell me where the glow plugs are inserted so that I can pull the connector off and test to see if there is voltage at the glow plutg itself
