Lugnut torque spec?
I'm rotating my tires for the first time on this truck. I was wondering if anyone knew the torque spec? I dont have a owners manual so I'm at a loss
Sent from my iPhone using Autoguide |
I have a 350 Dually, it uses 160 ft. lb.
pretty sure my haynes manual says 120 ft lbs.
3 shucka shucka's with a 1/2 air gun ain't that the spec?
i believe it is 115-120 ftlbs right around there
My manual says 150 ft./lbs. That's for a single rear wheel crew cab.
On the torque retaining lug nuts the washer will tell you in small print. I would like to say 140 but my discount tire days were a few years back and I'm with tony, 3/4 shucka shuckas lol.
Ding, ding, ding, we have a winner!
this is a dumb question but how ho you guys lift your truck? if you lift the fronmt with a jack you cant get a stand on that side and jack stands arnt tall enough to reach the frame. and the rotary lift is only rated to lift 9000 lbs
Jack stands on top of wood blocks. Nice truck.
workshop manual says 160
btw 2003kingranch a 9000lb rotary will take your unloaded truck up fine(as long as its a symmetrical lift). you'll need some rack extenders for the back but a crew cab should go up straight. regular cabs are a pain in the *** |
