Yay tax returns! New Oil Cooler and other stuff - Ford Powerstroke Diesel Forum
Old 02-15-2011, 03:42 PM
Looking for opinions! Getting my tax return soon and I need a new oil cooler (20* delta). So here is what I'm pretty sure I am going to do with it:
Coolant Flush
Change Oil Cooler
Updated Drain Tube
EGR Delete
STC Fittings
ELC Coolant
Probably Coolant Filter
Any other suggestions? Not going to be getting an x3 and tunes/exhaust till summer sometime.
Also looking for opinions on how to go about changing the oil cooler as well, as a good instructions.
Old 02-15-2011, 06:09 PM
Coolant Flush
Change Oil Cooler
Updated Drain Tube
EGR Delete
STC Fittings
ELC Coolant
I am looking to do most of that too with my tax return. What are STC fittings? I did the diesel site coolant filter already. What else should be done when doing the Oil cooler and EGR delete while you are already in there?
Old 02-15-2011, 06:45 PM
STC are fittings in 05-07 on the HPOP that are prone to failure, the updated ones are built better. Other than what I plan on doing, i don't think there is much more to do. Hopefully someone else will chime in
Old 02-15-2011, 07:08 PM
yhc yhc is offline
I will be working on these projects this weekend.
Here is a list of items I will be replacing in addition to oil cooler change and EGR delete. I consolidated the list after gleaning this and another forum.
Fuel Pressure Reg kit (3C3Z-9T517-AG)
Banjo Bolts x 2 (W302472) w/ Washers x 4 (W303659)
In addition to the updated Turbo Drain Tube (6C3Z-9T515-A) I will install the updated turbo feed tube as well (Int P/N 1845287C96 & Ford P/N 3C3Z-9T516-A)
I also am planning to rebuild the turbo while I have it out using the rebuild kit from International (Int P/N1870713C91).
Perhaps more experienced forum members can comment on these upgrades.
Old 02-15-2011, 07:27 PM
Nice addition I will add those to my list! And thanks for the PDFs too!
Edit: are the banjo bolts easy to replace???
Old 02-15-2011, 07:35 PM
Feedback Score: 4 reviews
While your in there, don't forget about the dummy plugs and stand pipes!
Old 02-19-2011, 07:50 PM
Can't wait till Monday! Gonna start it! First with the flush. Oil cooler is still being shipped be here Wednesday. Gotta go to Ford and get the banjo bolts, and find somewhere to get some ELC! Any suggestions??? <- would be much appriciated!
Old 02-20-2011, 01:38 AM
i'll be doing all this real soon as well. is everyone just replacing/upgrading with factory/ford/International parts, or are there better recomended after market plugs and stand pipes?
Old 02-20-2011, 05:47 AM
yhc yhc is offline
I am in the middle of changing out my oil cooler and EGR delete. Once you have everything disassembled to do your work, the 2 banjo bolts are easy to replace.
Old 02-20-2011, 07:21 AM
Yup here is my list of part numbers, but I didnt get them from Ford. Links are down below!
Oil Cooler: 3C3Z-6A642-CA, IPRResearch Oil Cooler
Intake Gaskets: 3C3Z-9439-AA, eBay - NEW-FORD-6-0-L-DIESEL-INTAKE-GASKET-SET-2003-2007
Upgraded Turbo Drain Tube: 6C3Z-9T515-A
Upgraded Turbo Feed Tube: 3C3Z-9T516-A
Turbo Hardware Kit: 3C3Z-9T514-AD
All the Turbo Parts: eBay - 03-07-Ford-Diesel-6-0-BETTER-TURBO-OIL-FEED-DRAIN-TUBE
STC Fitting Kit: 4C3Z-9B246-F, IPRResearch STC Fittings
EGR Delete: eBay - FORD-6-0L-03-07-EGR-DELETE-KIT-F250-F450-POWERSTROKE
Still Need to Get (will be checking at Ford)
Fuel Pressure Reg. Kit: 3C3Z-9T517-AG
Banjo Bolts: 2x bolts- W302472, 4x washers- W303659
Coolant Filter: From Sinister, MKM Customs
Restore and Restore Plus
ELC EC1 Coolant
All my eBay items I will vouch for. They were fast at shipping and communication was awesome. The seller for the turbo parts has a ton of stuff listed for our 6.0s, so if you need anything check there! They are here before my oil cooler has showed up! eBay User - hccs2/ Everything came with the Ford Instructions too.
Oh and this may help too! http://www.ford-trucks.com/ford-manuals/
Hope this helps!
