Its it normal for the coolant level to fluxuate? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 02-15-2011, 02:54 PM Thread Starter
I checked the coolant level today and it was about 3/4 of an inch below the min line in the degas bottle. Its normally between the min and max. (let the truck sit for about 20 mins after getting home from work today) I rechecked and it was still about 3/4 below the min line. I took the cap off the degas bottle and the level started rising, I watched it go back to the normal level. It took about 3 minutes. Is this normal?
I did have the ford dealership do a coolant flush about 3 weeks ago.
Thanks
Mark
2008 Ford F350 Lariat DRW
All stock
2012 Keystone Avalanche 330re
2007 Harley Davidson Ultra Classic
cmssorrell is offline
post #2 of 24 Old 02-15-2011, 03:01 PM
6.0 stroke's Avatar
normal but not that much of a fluctuation. in a tuned truck going up and down more is normal. in stock tuning mine barely moves and i have stock head bolts and egr cooler... with the tune it goes up and down but at most 3/4" total
2006 F350 Lariat cc sb
ARP head studs 245ft-lb, ford head gaskets
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
coolingmist water methanol 10 gph nozzle
afe intake
intake horn
6" skyjacker 20xd hoss 37 toyo mt
stock trans
6.0 stroke is offline
post #3 of 24 Old 02-15-2011, 03:05 PM Thread Starter
The truck is completely stock with 59,000 miles. Thanks for the reply.
All stock
post #4 of 24 Old 02-15-2011, 03:07 PM
6.0 stroke's Avatar
sounds like head gaskets or egr cooler... is the truck puking at all??
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
afe intake
intake horn
stock trans
post #5 of 24 Old 02-15-2011, 03:13 PM Thread Starter
There is white residue under the cap, nowhere else. ECT is 190 and EOT 198 at 65 mph. ECT 190 and EOT 194 in-town driving.
All stock
post #6 of 24 Old 02-15-2011, 03:15 PM
6.0 stroke's Avatar
blowing white smoke?... if your eot and ect are that close then im assuming your egr cooler is good... sounds like another set of ford head bolts are stretching
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
afe intake
intake horn
stock trans
post #7 of 24 Old 02-15-2011, 03:16 PM Thread Starter
No white smoke. Runs great.
All stock
post #8 of 24 Old 02-15-2011, 03:18 PM
6.0 stroke's Avatar
well hope your head bolts aint stretching... save some money for arps bound to happen if its not already.
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
afe intake
intake horn
stock trans
post #9 of 24 Old 02-15-2011, 03:22 PM Thread Starter
It's under an extended warranty with 3 years left, which is a peice of mind.
Mark
All stock
post #10 of 24 Old 02-15-2011, 03:25 PM
6.0 stroke's Avatar
that will put a smile on your face
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
afe intake
intake horn
stock trans
