High idle mod write up? - Ford Powerstroke Diesel Forum
Old 02-12-2011, 08:58 PM
Hey guys, I've tried searching around here for the past few days and haven't been able to locate a write up for the high idle mod.
Can one of you guys be so kind as to point me in the right direction?
Thanks
Sean
Old 02-12-2011, 09:10 PM
Illiana Chapter Director
Thanks
Sean
Here you go. High Idle Mod
Old 02-12-2011, 10:06 PM
Thanks a ton!
Old 02-13-2011, 01:00 AM
why would an average person want this?
Old 02-13-2011, 01:18 AM
Too make us feel above average! jk!
Quicker warm ups. (even though the truck will idle up on it's own when cold)
Jump starting a friends Ram.
Keep a/c going for when you want to "run in for something".
Something to use an "upfitter " switch for.
Coolant change.
Just another option to have.
And it is a very inexpensive mod to do.
Old 02-13-2011, 02:38 AM
It helps to prevent wet stacking during extended idling. Thats the main reason I'm doing it
Old 02-13-2011, 10:33 AM
Awesome.
Old 02-13-2011, 06:10 PM
Fan-of-the-Man3
Send a message via Yahoo to fanoftheman3
Does anybody have the info for the high idle mod for '04 with a 6 sd?
I can find it for the '05, but the wiring harness is different on the '04
Old 02-13-2011, 09:15 PM
Just another quick question, what type of switch have you guys used? I have a momentary switch that I can put in, or does it need a toggle switch? As I read the write up it seemed to me like a momentary switch would be fine as it just needs to see 12v for the rpms to kick up
Old 02-14-2011, 05:25 AM
I used a toggle with a LED light. Try the momentary switch, and give us some feed back on how it worked.
EDIT: today some time, I will do a momentary flick of the toggle to see if that works!
