bulletproof 6.0???
ok guys bout to drop some cash into my 04 6.0. what is a complete solution to make the 6.0 bulletproof. and i want performance parts to like bigger injectors, better turbo and programmers. but if someone can give me a complete list it would be nice. thanks guys
There's a few different opinions on here of what makes a bulletproof 6.0L.
Stage 1: Basic budget-level bulletproofing. -Tear down a complete a EGR bulletproof cooler, or delete it. -Flush with both Restore and VC-9, and replace with a ELC. -Replace the Oil Cooler while you're in there, to ensure its clog free. -Install a Coolant filter, ex. from Dieselsite.com Stage 2: Next level, a little more expensive. -SCT fitting replacement (if required) -Turbo Oil return line upgrade ('03-'05 trucks) -Change the Oil Cooler to a remote condenser or bumper mount radiator type unit. (Bulletproofdiesel) *Note: This removes the dependency of the Oil / Coolant heat exchange. This is the single largest reliability upgrade you can make to this truck. Stage 3: Particularly important for those Modding the 6.0L -Pull the heads, gaskets and stock head bolts. -Get the heads machined flat, identify and correct flawed heads. -Reinstall Heads using Ford OEM or Black Onix Gaskets, and ARP Headstuds. *Do not reinstall using OEM TTY headbolts. That's the basic rundown of Bulletproofing your 6.0L, and there's a considerable number of threads here to point ya more specifically in the right direction. Hope this helps, and let us know how your build goes. |
thanks man. everyone agree or does anyone else have more to add to the list of stuff for me to do to the truck
I agree 100%
100% Agree but add Swamps FICM
