first time shade tree owner servicing - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-11-2011, 01:48 PM Thread Starter
Thumbs up first time shade tree owner servicing
Gentleman, I purchased almost everything you guys have spoke about and need a few tips. I purchased all the relevant REV X products for fuel and oil treatment, I am using standard rotella with a premium oil filter (NAPA GOLD), and I got two quarts of the VC-9 from Motocraft. I have not located a source for RESTORE, and need some guidance as to where to find it. I read some guys flush with tap water and finish with distilled, is that alright or not.
I would like to know where to by the radiator filter kit that you guys talk about??? So far can't find it on line. As for cleaning the ERG valve can you tell me where it is located on the engine, an what to clean it with. Obviously, I am a newbie but I am not afraid to wrench around as long as I have the HELP from you experts.
Great forum with great Q and A's. Never been to a site with so much help with out any attitude.. Keep it up Lovin all the info...THANKS POOP
theoldpoop is offline
post #2 of 8 Old 02-11-2011, 01:53 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Don't use the NAPA Gold oil filter. They are junk. Go to Advance Auto Parts or O'Reilley and get a MotorCraft filter. You can find the coolant filter kit here. www.dieselsite.com
dhanna6powerstroke is offline
post #3 of 8 Old 02-11-2011, 01:55 PM
diablos30's Avatar
Quoted: 31 Post(s)
dieselsite.com for the coolant filter
flushing first with tap and finishing with distilled is fine
there is a cleaning kit available for the egr valve
Ford Diesel 6.0 EGR VALVE OVERHAUL KIT 2003-2007 SAVE$$ - eBay (item 360132733215 end time Mar-10-11 05:15:56 PST)
basically just some carb cleaner and o rings
diablos30 is offline
post #4 of 8 Old 02-11-2011, 02:20 PM
Lubbockguy1979's Avatar
Quoted: 4 Post(s)
Send a message via Yahoo to Lubbockguy1979
walmart sells the motorcraft stuff like 20 bucks dont skimp on the oil filter
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #5 of 8 Old 02-11-2011, 03:24 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
...THANKS POOP
Here is where your EGR valve is:
(to remove the EGR valve, remove the 2 bolts, twist until the bolt hole "eyes" are open, run heavy duty wire through each hole and make a loop above valve, take a broom handle or something similar and use the alternator as a leverage point and simply pull up. (now the truth, PULL HARDER THAN YOU THINK!!!!) Get the EGR valve o-ring kit at you Ford dealer about 9 bucks part #3c3z-9p455-ab
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 8 Old 02-11-2011, 03:34 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
When you go to change the oil and fuel filters, the oil filter cap and HFCM (fuel pump) use a 36mm socket. It makes is a lot easier for the fuel pump cap if you use one of these.
http://www.autozone.com/autozone/acc...ntifier=110279
When you go to remove the fuel filter on top of the motor, DO NOT use the square 1/2" drive hole, you may break the cap. Use a 24mm socket.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 8 Old 02-11-2011, 03:41 PM
Quoted: 4 Post(s)
Isn't that a fact. Should fill that sucker with epoxy or something to keep the temptation away from doing just that.
post #8 of 8 Old 02-11-2011, 03:43 PM
Quoted: 4 Post(s)
OEM/36 mm. oil filter socket (25411) | | AutoZone.com
i did that the first time. it was my last time. expensive mistake
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
