fueling question - Ford Powerstroke Diesel Forum
Old 02-10-2011, 06:52 PM
fueling question
at what point should i get an airdog II? does it hurt to just have it just to be sure i got good fuel pressure?
Old 02-10-2011, 07:28 PM
Feedback Score: 3 reviews
Depends on what you have done to your truck, or what you plan on doing. The stock pump will be fine for the basic power adders. Whether you are using the stock pump or aftermarket, you really should have a fuel pressure gauge.
Old 02-10-2011, 07:39 PM
im bout to do it all haha. black onyx gaskets, arp head stus, egr delete, oil cooler rebuild,powermax turbo, 175cc or 190cc injectors, coolant filter, coolant flush, cat elc, upgrade turbo feed and drain tubes, upgraded down pipe and a few other things. should i get the airdog II as well?
Old 02-10-2011, 07:44 PM
With aftermarket injectors it's almost a must. Do you have a fuel pressure gauge it wouldn't hurt to get that also
Old 02-10-2011, 08:01 PM
when i do everything to the truck in the next week or so im ordering an edge cts to monitor everything but i think im going to have to get a single fuel pressure gauge. unless someone else has got some ideas for all my gauges to monitor everything
Old 02-11-2011, 01:34 PM
???anyone???
