Cold start - Ford Powerstroke Diesel Forum
Old 02-10-2011, 12:59 AM
VFW MEMBER.
Cold start
Here is a link to my cold start video what do y'all think the problem is?
Stock:
http://www.youtube.com/watch?v=pxzy4...e_gdata_player
Tune
http://www.youtube.com/watch?v=aruX7...e_gdata_player
Old 02-10-2011, 01:46 AM
Obsessive compulsive
What oil are you running? Check FICM voltage while cranking. Personally, I would'nt rev it up like that until its warmed up a little more. If your using 15w40, switch to 10w30 or 5w40 synthetic and get a couple bottles of rev-x to put in there too.
Old 02-10-2011, 03:09 AM
It shouldn't be doing anything like that...especially at 22 degrees! How old is your oil? DO NOT rev a diesel like that when the motor is still cold...you shouldn't be going over 2k rpm until that temp gauge comes off the peg. Have it scanned for some codes...could be a bad injector(s) or bad FICM.
Old 02-10-2011, 03:24 AM
Or you will hear a few pistons pop out the side ....
Old 02-10-2011, 05:37 AM
Here's my 20 deg start:
Been runnin the T5 10w-30 and my truck really runs well
Old 02-10-2011, 05:47 AM
even when I had 15-40 in my truck i started at 2* and didn't have as much problem as that.i'd check into the FICM
Old 02-10-2011, 06:12 AM
By all means check your FICM voltage.
Old 02-10-2011, 07:17 AM
yea, check the Ficm.
Old 02-10-2011, 07:59 AM
Negative 6 cold start and nowhere near as bad as some of yalls...and I'm 15W40...
Old 02-10-2011, 08:27 AM
VFW MEMBER.
Ok so I running 5w40 rotella t6 with revx I only have 400 miles on this oil change. injectors are good, Glowplugs are good, gpr it good that only leaves the ficm I'll get to that when I can.
