140K 6.0 oil analysis, my first.... - Ford Powerstroke Diesel Forum
post #1 of 21 Old 02-08-2011, 01:14 PM Thread Starter
Carbon huffing animal
SixStringMadness's Avatar
Okay, I did my first ever oil analysis on my 2004 PSD with 140k on the ticker, and 4250 miles on the oil. Here are the results, I had it done locally here in Knoxville, TN
Wear Metals:
IRON: 11
ALUM: 1
COPPER: 2
CHROME: 0
LEAD: 1
TIN: 0
Contaminates:
SODIUM: 51
DIRT: 10
Engine Soot:
NONE
Fuel: NEGATIVE
Water: NEGATIVE
Solids: NONE
GLYCOL: Positive
Visc: 152
Grade: 40W
Iron appears to be normal
Aluminum appears to be normal
Copper appears to be normal
Chrome appears to be normal
Lead appears to be normal
Sample contains a slight amount of sodium. Possible beginning of a coolant leak, however a trace of anti-freeze may be oil additive binder. Sodium should be low with 0.1% water in sample.
No water detected
Solids: New oil or no visible metal or dirt detected in this sample.
Sample has positive antifreeze, possible leaking oil cooler core, or contaminated sample.
I had two 4 oz. bottles of Rev X in 18 qts. of this oil tested. I don't know if that could be the oil additive binder referenced or not. And I don't have the OEM oil cooler block any more, I have an external air-to-oil radiator type cooler mounted behind my condenser.
So if those with more experience than myself would comment I would appreciate it. Thanks.
ERIC - Tennessee Powerstrokes Chapter Director
2011 K1500 Silverado Z71 5.3L Vortec
2004 F250 Super Crew FX4 Powerstroke
1997 F250 Super Cab 4x4 Powerstroke
2004 K1500 Silverado Z71 5.3L Vortec
1999 F250 Super Crew 2WD Powerstroke ZF6
1998 K2500 Silverado 5.7L Vortec
SixStringMadness is offline
post #2 of 21 Old 02-08-2011, 01:22 PM
Coal Rolling = Posing
The sodium is absolutely the Rev-X man, I meant to give you a heads up on that when you were askin about adding it.
Sorry brother.
chvyrkr is offline
post #3 of 21 Old 02-08-2011, 01:29 PM
Goose350's Avatar
What Tom said. It will be in your system for a little while too. Last time I added Rev-X I waited two more oil changes and then got my oil tested. Sodium was still high.
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #4 of 21 Old 02-08-2011, 01:30 PM Thread Starter
No apology required my brother! Just looking for clarification before I panic and think I need HG's unnecessarily. Thanks!
post #5 of 21 Old 02-08-2011, 01:56 PM
Yeah you're good, I know the panic feelin!
Some of the Rev-X dealers will let you know about that before you buy it too.
chvyrkr is offline
post #6 of 21 Old 02-08-2011, 01:59 PM Thread Starter
I bought it from a place locally that builds custom transmissions. I thinks that's funny since the bottle says not for use in auto transmissions. Probably why they didn't tell me. They don't even know what it is really, just that us diesel guys come in a buy it all up.
post #7 of 21 Old 02-08-2011, 02:08 PM
jhmason21's Avatar
Hey Sixstring, did you use a kit or did you just take it to that shop? I want to get mine done, y'all know of anywhere near Nashville? Thanks brothers
MASON
2005 F350 SCSB
4" MBRP TBE
Edge Insight CS
Dieselsite coolant filter
PHP FICM hybrid flash
Sinister EGR delete
Upgraded FPR spring
SCT tuned by Gearhead
jhmason21 is offline
post #8 of 21 Old 02-08-2011, 02:38 PM
smokersteve's Avatar
Quoted: 20 Post(s)
iron 11 and lead 1, very nice!
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #9 of 21 Old 02-08-2011, 02:39 PM Thread Starter
I used a kit, but can do it right in there parking lot in the AM, and get results back that afternoon.
Not sure of any places in Nashville, but ask the local diesel shops if they take theirs somewhere local, that's how I found this place.
post #10 of 21 Old 02-10-2011, 12:21 PM
jhmason21's Avatar
Which kit did you use?
MASON
2005 F350 SCSB
4" MBRP TBE
Edge Insight CS
Sinister EGR delete
Upgraded FPR spring
