Trouble shooting for my supervisor - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-07-2011, 09:51 PM Thread Starter
Hey all-
I am trying to help out my boss and earn some brownie points. He has a 2006 F350 6.0 that is bone stock. He doesn't monitor his EOT/ECT (working on getting him to buy an Edge), and he is having some issues with the truck. Currently, his CEL is on and he took it to the Ford dealer. The dealer recommended a new FICM, Fuel PSI regulator, #2 Injector, air and fuel filters, and a unison ring. Anyway, we work in a pretty high altitude at 9100 ft above sea level. This past weekend, he drove the truck to Denver (5280 ft), and the CEL turned off and the truck ran like a raped ape. Upon returning to altitude and turning the truck off for the night, it ran horribly the next day. My boss describes the symptoms as "chugging" at WOT, and the turbo not sounding "right" even though the turbo is getting boost. I am kinda stumped with the fact that the truck ran great at a lower altitude. Any ideas? My thoughts were a cam sensor, but I am a rookie to diesels.
Thanks for the help!
2005 Ford F350 PSD CCSB
Edge Insight
ELC
Dieselsite Coolant Filter waiting to be installed
BugsWest is offline
post #2 of 8 Old 02-08-2011, 04:34 AM
mmandley's Avatar
Only thing that comes to mind is the MAP sensor.
Check this link out
http://www.ehow.com/how_4478865_trou...ap-sensor.html
http://www.intellidog.com/dieselmann/60bulletin.htm
08 F350 6.4 Lariat CC LB tows a 13 Moomba Mojo 2.5
2inch Level kit
Mini Max tuner
S&B CAi
Diamond Eye 5inch exhaust straight pipe
HID headlights, and Fog lights
EGR delete <planned next>
Ladder bars <in the future>
mmandley is offline
post #3 of 8 Old 02-08-2011, 06:27 AM
Quoted: 15 Post(s)
What DTC (code) did he get w/ the CEL?
How long has it been since the air and fuel filters were changed (and what filters were used)?
The fuel pressure regulator spring is a necessity IMO. Do it yourself or get it done. Of course it is always better to have gauges, but almost everyone I know w/ the original spring does not maintain the proper pressure at WOT.
Since he has a 2006, he should have a boost gauge. What is it doing?
You can read up on how to test the FICM voltages if you are interested. A quick search will bring up what you need.
You might also need a new Baro sensor. MAP/BARO/EBP should all read the same at KOEO.
It is possible that the turbo needs cleaning - possibly a new unison ring, but they can't know until they (or you) inspect.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #4 of 8 Old 02-08-2011, 09:29 PM Thread Starter
Bismic, I will get with him and get those details. I pulled his DTCs with my Edge, but I lost the piece of paper I wrote them down on. As far as I know, his boost guage is acting normally, but he says his turbo sounds "different" with less whistle. I will do the FICM test for him provided I can borrow an autogenuity (sp?) from a parts store. When his truck is back at work (he is out of town), I will pull those DTCs and post them in this thread. Thanks, guys!
Edge Insight
ELC
BugsWest is offline
post #5 of 8 Old 02-09-2011, 07:29 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
All you need to check the FICM out is a Volt meter or a Multi meter. Everybody should have one of them in their tool box.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 8 Old 02-09-2011, 11:55 AM
Feedback Score: 5 reviews
I totally looked at the title and read:
Trouble shooting my supervisor
ToMang07 is offline
post #7 of 8 Old 02-09-2011, 12:45 PM
ab2625's Avatar
Sounds like a rusty unison ring causing the vanes to stick in the turbo. You should be able to pull it out and clean it up with a resurfacing kit. Check this link.
04 F250 6.0 CCSB Lariat
ARPs, Insight CS, SCT gearhead & Quicktricks, RCD EGR Delete, MBRP 4" straight, Airaid Intake, upgraded banjo bolts, Blue spring, Harpooned tank, Dfuser Coolant filter, CCV filter, High Idle, ELC, 8" lift & 38's, Custom Ladder bars, RedHead steering gear, DDM HIDs heads & fogs, 20% tint, 08 console, 08 rear bumper, 08 Mirrors, 08 trans pan & filter & GOGO Solonoid
ab2625 is offline
post #8 of 8 Old 02-09-2011, 03:53 PM
superjet701k's Avatar
truck runs fine at lower alt. sooooo. its a air and fuel presure problems need more of both air presure and fuel presure. 1st new air filter and fuel presure regulator spring upgrade and do the banjo bolts also. 2nd clean egr valve and run ceatane boost in every tank of fuel. then check codes for things like map, baro, exhaust backpresure,
OIF 1 ARMY VETERAN
8' fisher MM2 plow
Dieselsite coolant filter
fuel presure reg spring
air box mod
6.4 banjo's
RAE batterys
CCV mod
2010 side steps
turbo back 4" no kitty
superjet701k is offline
