2003 Lift Kit - Ford Powerstroke Diesel Forum
Old 02-07-2011, 07:27 PM
Thumbs up 2003 Lift Kit
I have a 2003 250 CC with the 6.0. and i am stuck between either a leveling kit withs 35s on 18s or a 4 inch lift with 35s on 18s. Dont wanna go any bigger than 35s. So no need for a 6" lift. But anyway can you guys post pics of your trucks with a level or a 4" lift. Also with the 4" lift do you have to do anything with the driveshaft for the rear because of the angle or is it fine without doing anything to correct the angle. So if can post pics thanks because it will help me make up my mind.
Old 02-07-2011, 07:48 PM
u should go 6 inchs in front and 4 inchs in the rear would look sick
Old 02-08-2011, 04:40 AM
You can look in my pics i have a front leveling kit and run 35s.
1 think to consider before you lift the truck is how much towing do you expect to do. Lifting the truck effects a lot of the towing aspects.
Old 02-08-2011, 10:42 AM
Thats true u do have to put if ur going to tow inperspective
