Front & Rear Diff Change ?
So which oil is the best to go with amsoil or royal purple. Also just double checking 75-90 for the front and 75-140 in the rear. I do alot of towing. Thanks Guys
I put Royal Purple in the front and rear. It did help the stock rear diff lock engage sooner and it did hold a little longer before it would 1 wheel when boosting.
I went with royal purple 75-140 in both.
I used amsoil in front, rear, and transfercase and very happy that I did. The 4x4 system is not as pronounced as when I had the stock fluid. I changed the fluids at 30,000 miles.
I am not a big fan of RP products. |
What weight's did you use in diffs? |
75w-90 front and 75w-140 in the rear.
I see very little reason to use a thicker weight in the front. Last edited by smokersteve; 02-07-2011 at 11:26 AM. |
75w-90
http://www.amsoil.com/storefront/svg.aspx 75w-140 http://www.amsoil.com/storefront/svo.aspx Transfercase http://www.amsoil.com/catalog.aspx?code=ATFQT-EA Last edited by smokersteve; 02-07-2011 at 11:26 AM. |
Royal Purple here in all.
I got 2 gallons of Valveline Full syn 75/140 man that chit is expensive. 15 bucks a quart
Thanks steve! |
