Is there a cigarette lighter in the backseat area anywhere? - Ford Powerstroke Diesel Forum
Old 02-05-2011, 05:54 PM
I have an '07 Outlaw CC, got a pair of rear DVD players for my daughters, and was hopin i had a cigarette lighter in the console (i don't), or somewhere in the rear...
Any ideas?
Old 02-05-2011, 05:59 PM
What about getting a longer cord to hook up in the front on the dash? Or are you wanting them to be able to hook it all up on their own?
Old 02-05-2011, 06:17 PM
You could buy an aftermarket multi-plugin, run the wire under the seat and along the edge trim on the floor, and up into the fuse box and hard-wire it in. That's what I'm planning on doing. Not sure where I'd mount it. Haven't looked at it yet.
Old 02-06-2011, 04:47 AM
Yea that sounds like a good idea, maybe i'll just run it to a upfitter switch (make a good on/off switch for them also), and into the center console, drill a hole (if I can find a nice connector to make it look professional).
Old 02-06-2011, 04:51 AM
Something like this, but maybe more sleek?
Old 02-08-2011, 04:37 PM
Got mine done today.
Mounted multi-box on center column. This one also has a USB connection. I ran the wire down the column, and along the sill, up to the firewall, and over to the fuse box.
I wired it in with an "Add-a-circuit" pigtail. It just plugs into an existing fuse socket.
Old 02-08-2011, 04:39 PM
nice job!
Old 02-08-2011, 04:44 PM
The new 08 center console as an outlet in the back and are a lot nicer that the stocker.
Old 02-08-2011, 05:02 PM
Originally Posted by travsav View Post
nice job!
Thanks! I did a similar install on my work truck also.
