Couple questions
Ok so I have tried the seatbelt chime disable a couple times and it ain't working what could I be doing wrong I followed the owners manual also I have seen a few sigs saying door chime delete what is it and how do I do it thanks for all your help
this is from memory so i hope it works for you.
1. Get in truck put key in ignition and turn to on but dont start it. 2. Leave key on until red light on dash turns off. 3. Once red light turns off plug in then take out (each time in then out counts as one.) 9 times. 4. Red light will flash 3 times, then plug in and take out one more time. After that you should be good to go. |
[quote=Jayson41;2332804]this is from memory so i hope it works for you.
1. Get in truck put key in ignition and turn to on but dont start it. 2. Leave key on until red light on dash turns off. 3. Once red light turns off plug in then take out (each time in then out counts as one.) 9 times. 4. Red light will flash 3 times, then plug in and take out one more time. After that you should be good to go.[/quote Jayson, you quote on line (3) "Once red light turns off plug in then take out (each time in then out counts as one.) 9 times." I'm not clear on what you are referring to (plug in and take out)? |
the seat belt into the holder as if you are putting it on to drive away.
each time you buckle and unbuckle, wait 2 seconds between each step. go too fast and it won't register
a buckle and unbuckle counts as one time |
Ok got the seatbelt thing done now anybody know what the door chime delete is thanks again for all your help
