Tow Tune - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-12-2007, 09:36 AM Thread Starter
gowing82's Avatar
Tow Tune
Hey All,
I am just wondering about towing with the Edge Evolution. I have not towed with it yet. When you use the "tune" do you disengage the "tow/haul" on the shift? I will be towing a camper rated at 2850#
Let me know thanks..
gowing82 is offline
post #2 of 4 Old 07-12-2007, 09:53 AM
the tow tune for the edge, and the tow haul are two seperate things. The tow/haul mode is for the transmission it allows the trans to downshift to help in aiding deceleration. It also changes the shift curves as well. I dont know the in depth detail, but that is what it does. The tow tune is just a setting edge puts on there chips, it basically not as agressive as the higher setting files ie... level 3-5.
barry1me is offline
post #3 of 4 Old 07-12-2007, 10:47 AM
back in the saddle
shu873's Avatar
You can use the tow/haul along with the edge tow program. Like Barry said, two separate things. You don't really need tow/haul with that little bit of weight you're hauling, but I like to use it just because it saves my brakes a bit by helping down shift...
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #4 of 4 Old 07-12-2007, 11:28 AM
rankroddin250's Avatar
I got a manual mine just has the motor tunes LOL cant help ya out here
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
