??upgraded fuel pressure regulator?? - Ford Powerstroke Diesel Forum
Old 02-04-2011, 08:13 AM
ok guys i getting all the part together to bullet proof my 2004 F-250. but is there any point in a upgrade in my fuel system? if so what should i get?
Old 02-04-2011, 08:43 AM
bump to top
Old 02-04-2011, 09:55 AM
Depends on your plans for the truck. Get a fuel pressure gauge so you can se what is going on and do the FPR update. The very first thing you should do is invest in a good monitoring solution like an Edge Insight so you can monitor your ECT and EOT.
Flush the cooling system and change over to a Cat EC-1 rated ELC coolant. Delete the egr if you can. If you can't replace the egr cooler with a Bulletproof Diesel egr cooler.
Old 02-04-2011, 10:41 AM
the insight is on my list of things to get. but i have the edge juice platnuim right now so i can watch my EOT and my ECT. but how will know if i need to upgrade my fuel system and what is the FPR update
Old 02-04-2011, 12:03 PM
Upgraded fuel pressure regulator spring. It bumps up the pressure for the stock fuel system, part # 3c3z-9t517-AG. If the fuel pressure is under 45psi it can kill injectors, over 70psi blow injector o-rings.
