coolant flush help asap! - Ford Powerstroke Diesel Forum
Old 02-03-2011, 11:38 AM
I'm in the middle of the flush procedure and I've just done 4 distilled water flushes after the Restore, and there is still some foam in the system. How important is it to get it out 100% before adding coolant? I don't have enough distilled water on hand to do any more flushes, so if I don't have to, I won't.
Old 02-03-2011, 01:10 PM
Go get some more. You should have flushed till clear with tap water then flushed 4 times with distilled to get the tap water out.
Old 02-03-2011, 05:11 PM
Yeah, somehow I missed that detail. I did get more and flushed 2 more times. It's all good now. Thanks, Mitch
Edit: Here is a couple of pics of my setup
My home-built aluminum bracket
I couldn't find a 3/4 x 3/4 x 3/8 Tee, so I used a full sized one and went with 3/4 hose to the filter. I figured it can't hurt to have good volume to the filter. Seems to work great.
Old 02-03-2011, 05:41 PM
You're welcome.
Old 02-03-2011, 08:41 PM
What did you use for your 2 in leveling
Old 02-04-2011, 03:21 AM
Not sure I understand the question. Are you asking me how I levelled the truck?
Old 02-07-2011, 02:50 PM
Jersey Strokers Director
Send a message via Skype™ to Aronda1125
Just a quick question. How much distilled water am I gonna need if I do the 4 flushes at the end and then also to add to the concentrate? I just want to make sure I have everything b4 I get started this weekend. Alex.
Old 02-07-2011, 02:58 PM
Just finished my flush up right now. Added the coolant filter to it and everything.
I bought 25 gallons of distilled and still used every one of them. I could have used another 4 gallons i think.
Its basically 4 gallons each fill and drain.
When i went to drain my VC9 the first bucket was black water. I was like WTF man? Black?? Then after that each one for lighter and lighter.
The last bucket barely had any bubbles at all and the water was clear.
Now im filling with coolant and getting ready to let her warm up so the new T stat opens.
Odd thing is the new John Deer ELC stuff i got looks kinda yellow to me lol.
Old 02-08-2011, 11:46 AM
is it good to use something to flush the system or just water? Where do you get that VC9 from?
Old 02-08-2011, 12:22 PM
Yes you want to use a chemical to break all the junk in the system down so it will flush out. I got the VC9 at the local Ford Dealer.
