OK guys im gonna do my first oil change in my truck Friday
Ive had the truck about a month and half. when i bought it they changed oil for me. i dont know what kind of oil they put in it or what kind of filter that kinda scares me so im going to do a change. oh yea Ive got 3300 miles on the oil.im pretty sure im going to put Rotella T6 Full Synthetic 5w-40 in it and motor craft filter is there any special procedure to changing the oil? Ive never changed oil in a diesel. (vehicle wise) any help is apriciated |
I got another question. So does rotelka come on 4qt jugs or 5qt I need 15qt right?2003 6.0 And does it take all 15? I need to know how much to buy. I'm new to all of this
Sent from my iPhone using Autoguide |
Fully loosen the filter cap and leave it in the filter housing so it drains. Drop the drain plug and let it drain fully. Reinstall the drain plug, it's a good idea to replace the copper drain plug washer. Replace your filter and replace the cap O-ring with the new one. Lube the O-ring with a bit of oil and snug it down.
Also a good idea to drain your fuel/water separator. You will need a 6mm allen key to remove the drain bolt. |
Buy 4 1 gallon jugs and you should have 1 qt. left over.
On your next oil change get one of these works great
QuickOilDrainValve.com - the best way to change oil When you chage your fuel filters next time get one of these to ease your pain Diesel Technician Society Use Ford filter (oil-fuel-trans-air) only or Racor they make the ford filter. Hope this helps 2 stroker |
well pulled it in the shop today and changed it. i was pretty easy. bought 4 gal of t6 and motorcraft filter. $125 ouch!!!
and i should have took a pic of the filter that was in it. defiantly not a motorcraft. some limp pos./ oil didn't look to bad. glad i changed it, especially with that filter. also while i was under there i drained the water/ fuel separator so how often do you guys change your oil? i thought i read somewhere 10,000 miles but i dont like that at all. but what do i know
Change it at 5k. Only go over that if you have the oil analysis done. But 5k is a pretty safe bet even with dino oil. My truck is pushing 100k on dino oil only with the oil changed religiously at 5k with no stiction problems whatsoever. Also, as was stated earlier, stick with the motorcraft or racor filters.
I second the quick drain valve. It makes changing and sampling oil so much better, and cleaner. I do miss the canister filter of the good 'ole 7.3. I hate this cartridge filter.
