325 60 18 tires - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-02-2011, 07:29 PM Thread Starter
325 60 18 tires
will 325 60 18 tires fit a factory 2007 F350 FX4?
Colton is offline
post #2 of 8 Old 02-02-2011, 08:00 PM
i have a 2" level on my f350, and put those tires on my stock wheels with no rubbing! i would think they would fit with no lift but maybe a liitle rub on tight turns.
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #3 of 8 Old 02-02-2011, 08:15 PM Thread Starter
how hard is the level to put on?
Colton is offline
post #4 of 8 Old 02-02-2011, 09:24 PM
smokersteve's Avatar
Quoted: 20 Post(s)
not hard at all. Have an extra hand and a few jacks, you can do it in an after noon.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 8 Old 02-03-2011, 02:48 AM
325's may "fit" on the factory 18's, but that doesn't make it a good idea. They should be on a 9-1/2" or 10" wide wheel, 9" should be considered the minimum. If you put them on the factory wheels, you will be riding on the center of the tread, even if they are underinflated. If you want to run the factory wheels, consider a 295/65 or 295/70.
WLDHRSE is offline
post #6 of 8 Old 02-03-2011, 03:49 AM
FDiesel05's Avatar
Not to hi-jack, but running a 295/65 will it rub on stock height?
2006 Ford F-250 Lariat CC SB
MBRP 4" turbo back
-bob
FDiesel05 is offline
post #7 of 8 Old 02-03-2011, 06:01 AM
mmandley's Avatar
Most tire shops will fit 1 tire for you if they know your buying an entire set and then you drop the truck and turn lock to lock.
I have a leveling kit on my truck and run 325/50/20s and i get no rubbing. Its close to the fenders when turning lock to lock but its not rubbing.
08 F350 6.4 Lariat CC LB tows a 13 Moomba Mojo 2.5
2inch Level kit
Mini Max tuner
S&B CAi
Diamond Eye 5inch exhaust straight pipe
HID headlights, and Fog lights
EGR delete <planned next>
Ladder bars <in the future>
mmandley is offline
post #8 of 8 Old 02-03-2011, 08:10 AM
To those that may not know, most F350's sit bout 1.5-2" higher than F250's stock.
I am no nascar mechanic but my levek kit took me less than 45 min from start to finish.
gblauf is offline
