Boost referenced fuel pressure
Whos done it? What system do you have and how do you have it set up?
Just a bump
Unbroken did this
Yeah, now that you mention it I remember that.
What are the benifits?
Less stress on the fuel pump.
By hooking up the boost reference on the regulated return you run the risk of over pressurizing the fuel system and causing harm to the injectors. The injectors like anything between 45 and 70. So, you would need your base pressure set to around 45psi with no boost. When you are at 20psi of boost, your fuel pressure will be at 65psi. Most (if not all) of the fuel pressure regulators have a 1:1 boost reference. You could get a Raptor pump and a tank sump. Set the regulated return to 65 and you shouldn't have but minimal fluctuation during WOT.
If I were to do it that is what I would do. Set it at 45 or 50 with a 1:1 up to 65. Its not high on the list, but is a possibility for when I get a pump and sump. |
| Tags |
| boost, boost referenced fp, fuel pressure |
