6.0 HELP!!!!! - Ford Powerstroke Diesel Forum
Old 02-01-2011, 06:56 PM
6.0 HELP!!!!!
someone tell me whats up! My EOT is running between 190-212 and my ECT is running between 184-190. i feel like this is wrong. wouldnt it be the oil cooler. btw i have a 2004 F-250 with the 6.0. but help!!!!
Old 02-01-2011, 07:16 PM
From what i have been told it shouldnt only be up to a 15 degree diff. It sounds like oil cooler and egr failure. Ur at 22 degree diff so i would jump on it before it breaks the bank.
Old 02-01-2011, 07:24 PM
The Silent Service
You should get that truck in the shop first chance you get. My temps were only 19* different and I had blown the head gaskets. Are you loosing coolant?
Old 02-01-2011, 07:34 PM
well i changed my t-stat and lost the coolant in the degas bottle and when i filled it i filled it to the max line and it blew coolant till it got to the min line and it hasnt blowen coolant since
Old 02-02-2011, 07:48 AM
anyone else got an opinion
Old 02-02-2011, 08:02 AM
Almostdunfukinwidit
Rebuild your oil cooler
Old 02-02-2011, 09:43 AM
The way you threw your number out there it is hard to tell what is going on. Check the temps at full operating temp cruising without a load at 65-70 mph. If the delta is more than 15* rebuild your oil cooler.
If you think you need to rebuild the oil cooler do it. It gets more expensive once the other stuff starts blowing.
