coolant filter - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-01-2011, 06:07 PM Thread Starter
Quoted: 4 Post(s)
coolant filter
I just installed a coolant filter and did a coolant flush this past weekend. Can you tell me how often I need to change the coolant filters?
fireryan is offline
post #2 of 11 Old 02-01-2011, 06:11 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Most go until it plugs.
Dieselsite recommends first one at 300 miles, second at like 1000 miles and then when plugged.
My first I changed at 300-some sand and stuff, like a table spoon full.
1000 miles-found about the same.
Third one plugged at 5000 miles, lots of crud and stuff in it. Fluid that came out of filter had a lot of floating stuff in it.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 11 Old 02-01-2011, 06:36 PM Thread Starter
Quoted: 4 Post(s)
how do you know when its plugged
fireryan is offline
post #4 of 11 Old 02-01-2011, 06:49 PM
Quoted: 4 Post(s)
Did you do the Dieselsite filter? If so, the return hose from filter base to hose to degas bottle will be cold. You can feel the in coming hose to filter will be hotter than heck.
post #5 of 11 Old 02-01-2011, 06:50 PM
Jetmek319's Avatar
Send a message via MSN to Jetmek319 Send a message via Yahoo to Jetmek319
The only way i can tell on mine is the return line out of the filter will not be warm when the truck is at normal temp. Cut open your filter when you change it...you'll be surprised at the amount of poo that is inside...
Never, ever moon a werewolf!!!
2004 F250 SD 6.0 Crew SB,
Auto, CX Gray, AFE Stg II, 4" Turbo back MBRP exhaust, Stage I Fuel mod, Gunner Chrome, Recon Plastics, Marinco mod, Rhino Lined, DBA/Hawk Brakes, SCT Livewire w/ Elite Diesel Toons
, A.R.E Bedcap, Mag Hy-Tec Diff cover, Home Engineered Oil Bypass System, Kenwwod DNX5120, Clifford Auto-start, 58V Swamp's FICM.
= :burnout
Jetmek319 is offline
post #6 of 11 Old 02-01-2011, 06:51 PM
dusted4eva's Avatar
Send a message via MSN to dusted4eva
the first change for me was 3 months lots of pepper(pepper being the fine metal particles. Then 6 months less than half the pepper now once a year with only traces.
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod,
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
Diesel Site Coolant Filtration System
dusted4eva is offline
post #7 of 11 Old 02-02-2011, 04:07 AM Thread Starter
Quoted: 4 Post(s)
thanks guys
fireryan is offline
post #8 of 11 Old 02-02-2011, 07:14 AM
smokersteve's Avatar
Quoted: 20 Post(s)
I went 7,000 miles on my first one. Just wait for it to clog.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #9 of 11 Old 02-02-2011, 09:03 AM
bfrank81's Avatar
I've had my first one in for about 3300 miles. I did a flush before installation. When I grab the return line it still feels warm. As long as that stays warm I will let it go until my next oil change. In about 2k.
Remember it's a by-pass filter. if it gets clogged it will not hurt anything. So let it run for a while. Changing it at 300 miles is just trowing money for a filter down the tube. That's my opinion.
Brian
bfrank81 is offline
post #10 of 11 Old 02-02-2011, 10:38 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
First change in 1 month, 2nd change 3 months after that, then anually.
RIP Mitch
the Org crew
PGreenSVT is offline
