EC1 and Coolant Additive? - Ford Powerstroke Diesel Forum
Old 02-01-2011, 09:59 AM
Hey fellas,
New here. Just bought 6.0..fixin to flush out the gold as indicated here. I had no idea.
Question: My old 7.3 required coolant additive (can't remember the name for the life of me) to prevent cavitation. I used fleetguard test strips and, when necessary, added it based on the strip results.
After flushing and changing to the EC1, do I still need to monitor cavitation additive levels? Or am I putting the sileca right back in?
Thx
Mel
Old 02-01-2011, 10:31 AM
Illiana Chapter Director
Originally Posted by Desert Mel View Post
Hey fellas,
Thx
Mel
If you fill the system with a 50/50 mix of ELC EC-1 coolant and distilled water, I don't think you have to have any additive.
Old 02-01-2011, 12:04 PM
Hey fellas,
Thx
Mel
No test strips No additive Just get 4 gallons of ELC coolant CAT EC-1 Rated concentrate and Restore and Restore+ here is the flush outlined my Mitch
2 stroker
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one. You can skip the block drains if you want except for the final drain before adding fresh coolant. You will just have to flush a few more times to get the block clear.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with tap water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with tap water. Drive truck or run on high idle for 60-90 minutes. Drain and flush 3 or 4 times.
Add 2qts VC-9 or 1/2gal of Restore Plus, top with tap water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water if you are draining the block or 5 times if not. This is to replace any tap water in the cooling system with distilled water and very important.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
Hope this helps.
Mitch
Old 02-09-2011, 10:27 AM
Thanks fellas
