Originally Posted by caneintn
Headed out Friday night and was on the interstate. Until this point I had driven truck only on level areas. Started up a long ascent and about a mile into it the truck missed and started to act like it was starving for fuel. Headed back home with mixed driving. Pulled the water plug and chocolate milk came out followed by a lot of water. Replaced both filters with motorcraft filters. Previous filter looked to be a wix with no wrap around the seperator.
Well, the fields highlighted in bold red definitely can't be good for anything in the fuel system, ESPECIALLY the injectors.
Took it to Southeast Dielsel this morning and they called me after lunch to tell me I had some water in filters but that the truck had thrown codes. Told me I have a bad injector and 2 faulty glow plugs.
I wouldn't be surprised at all with that diagnosis. For what it's worth, it only takes ONE cylinder not pulling its weight to make all the difference in the world. Your glow plugs would only be considered a cold starting aid. But a bad injector will definitely cause what you describe.
Given the information provided above, I would run down to your nearest Ford store and pick yourself up a new HFCM (part number PFB-93) along with the update harness (part number 6C3Z-9F759-A), an update fuel pressure regulator that bumps pressure up to 65 psi from the previous 55 psi spec (part number 3C3Z-9T517-AG) and even an upgrade to the knob style water separator drain (part number 6E7Z-9C082-A) to rid yourself of any fuel pressure issues once and for all. Oh and course, replace the faulty injector too. Once all this is done, make sure you fuel your truck up at a known good supplier that sees a regular flow of diesel trucks fueling up often.
