Heater blows lukewarm to cold, how many different areas do i need to look at to fix? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-23-2011, 03:19 PM Thread Starter
14mins's Avatar
My 2005 F250 heater is basicly a non heater. At best it blows lukewarm but most of the time it blows in the 50 degree range. My wife refuses to ride in it. I do have a egr bypass installed. The radiator is full and i have no issues with coolant loss. 160,000 miles and never a issue with the heater. Truck runs fine with no issues besides no heat and my ABS is non working at the moment.
What areas do i need to look at? The black flow control valve by the passenger side seems operational.
The A/C works fine, i can adjust the temp with a turn of the dial.
Thanks for the help.
2005 YELLOW f250, REMOVED PROGRAMMER, yellow guage cluster background, JL 5 channel amp, Infinity speakers, JL sub in custom box, aftermarket seat heaters, cab lights, 3 inch Lift. idle mod, 35 inch tires. 1979 YELLOW Corvette, 2005 YELLOW Dodge SRT 4 TURBO Neon, 2005 YELLOW Monte Carlo SS and a 1987 Buick Grand National for when the NEED FOR SPEED hits. I have dreams of painting this car YELLOW!!!!!!!!!!!!!!!!!!!!!!
14mins is offline
post #2 of 7 Old 01-23-2011, 03:45 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The inline valve is not a back flow control, but a valve that closes off coolant circulation to the heater core to get the cab cooler when using the A/C.
There should be a gray vacuum hose that connects to it.
You could also get the truck up to temp and feel the heater hoses, the hose with the valve is the inlet hose and the other the outlet. See if they feel the same heat temp. If there is a noticeable diffrence, you may have a bad inline valve that isn't opening, air pocket, or blocker heater core.
If both hoses feel the same in temp, you may have a blend door that is not working properly.
Edit: is the coolant in the degas bottle at the proper level?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 7 Old 01-23-2011, 04:37 PM Thread Starter
14mins's Avatar
Lilpooh- Thank you for your response. I will check that in a little bit as i have a 40 mile trip i have to make.
The coolant level is fine in my degass bottle.
Do these trucks have thermastat issues? I have had toasty heat for the last 2 winters to be out cold this one.
14mins is offline
post #4 of 7 Old 01-23-2011, 04:44 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Do you have any way you can monitor coolant temps
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 7 Old 01-23-2011, 11:14 PM Thread Starter
14mins's Avatar
The valve on the rear passenger side does not have any vaccum going thru it . Does not make any difference wether i have the controls set to heat or AC.
I did install a different radio this summer, any chance i screwed up something at the controls inside?
No way to monitor the temps. I do have a point and shoot temp gun.
14mins is offline
post #6 of 7 Old 01-24-2011, 06:04 AM
14mins: I see you live in Aledo. Texas? If so, I live about 5 to 6 miles from you and I have AutoEnginuity in my garage. If you like, you are welcome to drop by and we can run a diagnostic check using AE.
deucer is offline
post #7 of 7 Old 01-24-2011, 09:39 PM Thread Starter
14mins's Avatar
duecer- Thanks, i will send you a pm.
I would rather deal with a bad injector as to chase these issues around.
14mins is offline
