Egr throws a light only when towing uphill?????? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-23-2011, 09:31 AM Thread Starter
So my buddies has an 04 and when he's tows up a grade the power is cut down like hitting a rev limiter and it throws a code for the egr valve. he can tow for 200 miles flat ground with no problems, as soon as the truck climbs it hits. He tows a car trailer with a 4x4 rock crawler on it.
stop towing uphill and light goes away and truck runs fine months at a time with no light. Tried cleaning the Egr valve to no avail.
thoughts????????????????
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #2 of 5 Old 01-23-2011, 09:53 AM
Well the motor is trying to save itself, it is defueling or going into a limp mod.
I would get a set a gauges on to see what the difference in EOT-ECT are max 15* but i think 10* your cooler are getting plugged. Has the coolant been flushed running the Ford Gold Cxxp, the turbo also may need to be cleaned the unison ring may be frozen does he run any centane boost in the fuel to keep the EGR valve and turbo clean
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 5 Old 01-23-2011, 11:15 AM Thread Starter
it has ford coolant, and never any additives, just diesel!
gblauf is offline
post #4 of 5 Old 01-23-2011, 11:22 AM
Well i use the ford centane boost and here is another post running over on the DieselStop
Changed the Coolant Filter..... - Diesel Forum - TheDieselStop.com
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
post #5 of 5 Old 01-23-2011, 11:24 AM
Have a look here.
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
