Ok what next?
My 05 6.0 was built 01/05 with 80k. So far I have fixed/repaired the following.
1. Swamps FICM 2. SCT fitting 3. Oil rail dummy plugs 4. Cleaned turbo 5. Repaced oil cooler 6. Bulletproof EGR cooler 7. Flushed it VC-9, Restore and filled it with Zerex ELC. What else is going to go wrong with this thing before I throw a roadflare in the front seat? ![]() I know the HG and studs are in order but what else do I need to do? Like put in the H2O bypass filter? Just wondering if I need it even though I put enough distilled water through my system to fill a small lake...lol |
I would add a coolant filter, but I wouldn't worry about HG's and studs until you start losing/puking coolant.
Now it's time for gauges, turbo back exhaust, and custom tunes. |
Do you really need the coolant filter with the ELC coolant?
thanks SS6 |
I would think of it as a safety net IF you did a good flush, but mandatory if you didn't. I don't know if my flush was extreme or not but my brother (Calkidd) and I flushed mine yesterday (the new oil cooler and EGR cooler were just installed) and we did his today.
We did the VC-9 with the one hour run, flushed it, Restore for one hour and flushed it pulling the block plug 6 times, then flushed it with distilled 3 times and added 4 gallons of ELC with about a half gallon of distilled. Don't know if thats excessive, but I'm pretty sure we got anything that was there to get. |
I would definitely get the coolant filter. I did a complete flush of my system until everything came out clean, and and then added the filter. I just changed the filter not too long ago, after about 1,000 miles, and couldn't believe the sand and gunk that was trapped in the filter element. And yes, I used the VC-9 and Restore. I am a STRONG believer in the coolant filter.
did you happen to install the updated turbo drain tube?
seems like you got it right to me, but add a coolant filter for sure.
BTW readers, flush the cooling system BEFORE the new oil cooler is installed so you dont clog up the new cooler with all the gunk |
