how much are 6.0 fuel filters supposed to cost? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 55 Old 01-21-2011, 05:49 PM Thread Starter
jeeplj8's Avatar
I was in NAPA tonight picking up wiper blades and shocks. I told them to throw in a fuel filter as I figured it should be changed (truck is new to me with 175K). The house brand was 49.99. Holy smoke!! I am used to Cummins fuel filter which was about 10 bucks online from fleetguard.
Are 6.0 fuel filters really that much? How often should you change them?
05 F250 King Ranch crew cab - bone stock for now, new to me April 2013, 56K miles
05 Volvo S60R, 300+ hp and AWD
09 Audi A4 Qautro 2.0T, AWD and 30 mpg!
06 Malibu LSV Wakesetter, 383 stroker
13 Coachmen 320BHDS - 10K lake house on wheels
81 Jeep CJ-8 (in progress); 5.7 HEMI; LJ (extended) frame, 3.5 RE lift, flatty fenders
jeeplj8 is offline
post #2 of 55 Old 01-21-2011, 05:51 PM
bfrank81's Avatar
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
[FD-4616] - Motorcraft FD4616- Ford 6.0 Liter Turbo Diesel Fuel/Water Seperator Filters - $47.95
Brian
bfrank81 is offline
post #3 of 55 Old 01-21-2011, 05:51 PM
Yeah they're a bit more $$$. I run the Wix (NAPA) filters as well, but I get them from fleet filter. Bunch cheaper there, and they ship to my door.
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
post #4 of 55 Old 01-21-2011, 05:51 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
It actually should be two filters. I pay about $100 every 10k miles for mine from Ford. Then again I only use OEM filters.
Stiles likes this.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #5 of 55 Old 01-21-2011, 05:54 PM
f250ghost's Avatar
I wouldnt use anything but OEM filters...just some advice. Skip to 6:40 for Fuel Filters
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #6 of 55 Old 01-21-2011, 05:54 PM Thread Starter
jeeplj8's Avatar
what site do you order from?
jeeplj8 is offline
post #7 of 55 Old 01-21-2011, 05:57 PM
majek5's Avatar
Got mine from the International dealer for around $35. That is for both filters.
Stiles likes this.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #8 of 55 Old 01-21-2011, 05:58 PM
topdwg's Avatar
Wow you are getting robbed. $100 for Motorcraft fuel filters?
You should shop here and save a little money. Even with shipping you'll save about $40...
Ford 6.0 Liter Turbo Diesel Motorcraft FD-4616 Fuel/Water Seperator Filters(FD4616): Pick Up & Excursion-REPLACES MOTORCRAFT FD-4604-NEW UPDATED - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #9 of 55 Old 01-21-2011, 05:59 PM Thread Starter
jeeplj8's Avatar
According to website above, Racor makes the Motorcraft filter...but of course the Racor is cheaper. So are the Racor actually the same filters?
jeeplj8 is offline
post #10 of 55 Old 01-21-2011, 05:59 PM
This one
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
