What is your voltage at idle? - Ford Powerstroke Diesel Forum
Old 01-20-2011, 03:08 PM
I have a edge cts insight and noticed that at idle my voltage would get a low as 12.4v for long periods of time. And sometimes I would get up to 14.0v at idle at time then it would drop down to 13.0v. Is that a normal voltage reading? I just replaced my batteries not even a month ago. Is this a sign of the alternator going bad? I noticed on the cts it sort of flickers when the voltage drops so low.
Old 01-20-2011, 03:12 PM
Not sure about the alternator, but it very well could be it.
I use a Scangauge II and it reads at idle 13.7-14.2. Never lower than that at idle.
Do you have anything loading it?
Old 01-20-2011, 03:13 PM
Feedback Score: 3 reviews
Check your ground connections. Especially the pass side in front of block where the battery ground cable gets bolted to the block.
Old 01-20-2011, 04:38 PM
I had similar readings and it ended up being my alternator. I would get it checked.
Mine reads 13.7 to 14.2 now.
Old 01-20-2011, 04:42 PM
Illiana Chapter Director
Mine never reads below 13.5
Old 01-20-2011, 04:51 PM
Sounds like your alternator.
Old 01-20-2011, 08:01 PM
Im leaning more towards alternator with all ya'lls replies. Does anyone know how many amps a 2003 f350 with the 6.0 alternator would put out?
Old 01-20-2011, 08:05 PM
amdriven2liv
I have nothing loading.
Lilpooh
I will check on that a.s.a.p.
Old 01-20-2011, 08:34 PM
Mine also is 13.7 to 14.2V
Old 01-21-2011, 09:13 AM
There is two alternators if I remember correctly. A high output one and a standard one. A standard one should be fine unless you're drawing tons of power for accessories.
