what injectors to get????? - Ford Powerstroke Diesel Forum
Old 01-20-2011, 06:48 AM
i got an injector going out so im just going to replace all 8 of them. which should i get? are stock injectors good? i want power but i still tow like one or twice a week
Old 01-20-2011, 06:53 AM
Illiana Chapter Director
155's-165's are probably as big as you want to go if you tow. A lot of people really like Casserly injectors. Ryan Casserly Full Force Diesel Powerstroke Injectors
Old 01-20-2011, 06:55 AM
thanks man you are answering all my questions today haha
Old 01-20-2011, 07:01 AM
Are you getting a rough running, cold start issue? If so, you might have what is called "stiction" which has to do with the spool valves in the injectors. You can try adding Rev-x to the oil which helps a lot and is way cheaper than injectors. REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil It is designed to help cure the stiction issue.
Old 01-20-2011, 07:08 AM
there is no cold starting issues but there is a for sure rough running issue. when i add that additive doi need to do a fresh oil change?
Old 01-20-2011, 07:10 AM
RCD vs. Elite vs. Cass
The best advice I can give to you is read. Search, read, read, and then read some more. There is so much information on this forum as well as others that is quality, personal experience. I can't stress enough to do your research. A set of injectors, even stock reman's are over $2,000 if you start looking into performance injectors up to & over $3,500. These trucks are expensive!
Good luck and don't be afraid to ask questions!
Old 01-20-2011, 07:14 AM
Does the rough running go away or get better as the truck gets warmer?
Old 01-20-2011, 07:15 AM
i know. i dont think ive stopped reading since i joined this site and dont even feel like ive scrached the surface hahah
Old 01-20-2011, 07:17 AM
yes the truck runs alot better once warmed up. and will sometimes run rough at stops.
Old 01-20-2011, 07:19 AM
Before I bought a set of injectors, I would do an oil change and add some Rev-X. I've used it in my truck for a rough running issue when cold and within 3 days it was gone.
